Couldn't find anything using the search. I'm wondering if there's any actual negative effect on the car if I remove the electrical connector for the low brake fluid warning on the master cylinder.
Poodles;1630991 said:Bzzzz wrong. It's a safety device. If it detects low brake fluid it disables the cruise control.
Poodles;1631072 said:Unless you want to eliminate a safety feature...
Poodles;1631086 said:Yes, it's also a safety feature that tells you if you're low on brake fluid. Can't think of anything worse than having no brakes...
