I haven't seen much people run this in there R154 trannys, so im just wondering if anyone else is other then Duane and if there's any differences in its use or reviews please?
Description (From Site)
MC-10075, Heavy Duty Bearing Cover $45
"Heavy Duty Bearing Cover Plate
Included free on all R-transmission rebuilds!
Fits all R-series transmissions [R150F (V6), R151F (Turbo 4Cyl), R154 (Supra), etc]. CNC machined from top quality tool steel and will long out live the factory original. As the factory unit wears out it fails to properly position the main shaft. This heavy duty unit does a much better Job of holding the shaft in the proper position. Includes set of 4 bolts."
http://www.marlincrawler.com/htm/transmission/trans_parts.htm
Let me Know people =) (about all there parts if you've bought from them)
**EDIT**
They ALSO sell parts for the transmission (bushings,bearings,Pressure plate bolts etc.)
ALSO they sell cheap clutch kits & flywheels =)
http://www.marlincrawler.com/htm/transmission/clutch.htm
**EDIT**
