Okay, wasnt sure. I was reading "free of engine deposits" as "no more from whats already there." Thanks for clarification!
jdub;1044961 said:I wish Neo would publish more info on their oils...how do you know it's ester based?
(ester is good stuff...Red Line is also ester based)
BTW - RP engine oil does contain a healthy dose of ZDDP (zinc) as an anti-wear additive. That's why the SBC crowd running flat tappet motors like it so much. It also has a high TBN to take care of any blowby for those high HP motors with the rings gapped a bit wide. RP is a good oil, but the rest of it's additive pack (detergents, dispersants, etc) is not as good as others available...if you want to use it on the street, I would recommend analysis every 4K (and a filter change) to make sure it's doing it's job.
Im Chris Brown;1045316 said:My friend uses AMS in his RSX and he loves it.
i understand an RSX isnt a supra, i was asking him a question and he said AMS is like a step above the RT-90 and most people dont use it because its more difficult to get ahold of and costs more money. Would AMS be better?
Supraboy89;1045044 said:sup guys while we are on the subject of oils. whats the best lube for the rear end.
bluedragon17;1045555 said:MTL is what I use. Same as JetJock havent had any complaints whatsoever about it. Perfect shifts everytime and my car is daily Driven too.
Poodles;1045563 said:Ford gear oil with the additive. Synthetics tend to make the rear end noisy...
