Adjuster
Thanks man.. The math works out to that 77% number, but I'm with you on the "I'd rather tune with less fuel pressure" than possibly raise the timing up to where it would cause problems.
Does anyone know how much the timing actually changes across the KS signal rate? (So as Hertz rate increases, the timing should decrease, and does the TCCS use pressure at all in setting timing? I don't think it does, but I'm not an expert on the TCCS either.. Perhaps JJ could chime in here?)
At what point do the injectors fail to have a good atomization pattern as the pressure goes down? I realize that the fuel droplets will be larger as the pressure drops, but what reall size difference will happen between say 30psi, and running them at 20psi? (Educated guess here, it's going to make some fuel drop out of the airflow at low rpm/idle, and that's going to possibly make it run poorly, especially when it's cold, much like a carburated engine.)
There is a point too where the fuel pressure will not drop down, no matter how much you adjust the regulator... (I believe it's higher than 20psi. So really, IIRC, the lowest fuel pressure I could get before was 24psi.. ? It's been awhile since I was adjusting the pressure to see what it was going to do, and how low it would go... The engine died on the 550's IIRC at about 24psi, so perhaps on the larger injectors, it might be able to be adjusted lower too? IDK.)
But, this puts me into a guessing mode on what mainscale to pull... (I know there is a math formula to calculate what injector flow is at like 43psi, and then what it would be a lower psi rates.. but I'm no math wiz.. I'll look at RC's site, IIRC, there is a calculator there..)
Thanks... LOL
Anyone else think pulling 77% is just crazy?
Oh, and my motor really does displace 3.24L exactly.. (Well, there are a few decimial points difference, but that's what it displaces
84mm bore, and 97.5mm stroke IIRC.
Did the RC calculator again, and I remember doing this before, and choosing the 780cc injectors for this reason.
To get a 650crank shaft HP capable 7MGTE, you really need to have injectors close to this size.
At 55psi final fuel pressure. (Assuming I'm adding 25psi of boost to 30psi base pressure..)
RC calls for 759cc injectors.
Just for fun, let's look at 550's and this calculator.
To get 450 crank hp, you need 526cc injectors being fed 55psi fuel. Pretty conservative numbers as most 7MGTE's with 550's and our engine/fuel setup generally are putting out 420rwhp at 18psi on a 60-1 bolt on, and some have made more, or less than these figures on 550's and similar fuel pressures. (Base of around 30psi with the 20 to 25psi of pressure added during boost.)
I really don't think I'm that crazy far off on the numbers considering that people have made more power than 650 with injectors this size, and less sophisticated controls than the Translator Pro... We at least can see where the ignition advance is going, and even if I'm brave enough, pull some timing advance to limit detonation. (I've thought about adding a methanol spray system that starts adding spray at 20psi, much like Mike has done to his Supra.) I'd like to get this to work on gas alone however if possible. (And I have some Toulene that I can add to raise octane up when I'm running high boost anyway... Might build a system that sprays pure toulene v/s methanol... Just need to find something that is resistant to that suff, it's nasty when it's pure..!)
Thanks... LOL
