I have been having trouble setting up my MAFT-Pro unit from day one. I was hoping that by posting my settings, someone who is a lot smarter and experienced than me would be able to point me in the right direction and explain what I am doing wrong.
Below are the settings presently on my unit. Most of them are "as shipped" and have not been changed due to either the lack of proper explanation and documentation or the fact that I don't dare change them for fear of blowing up my car. I am having trouble with the idle, AFR fluctuation at most all RPM's, Cruise, Boost and WOT settings. These seem to be common issues with all the people I have talked to.
My vehicle is a 1990 Supra Turbo. Mods include: 60-1 Trim CT-26 Upgraded Turbo, AFPR set at 34 psi running, Walbro 255l/h pump, RC 550's, full 3" turbo back exhaust with a high flow cat and flowmaster muffler. Timing is set at 11 BTDC. Brand new NGK plug wires and NGK 6097 plugs set at 0.030". Idle vacuum is a rch over 20 inches. MAFT-Pro is set up for Speed Density mode with the IAT sensor located in the 3000 pipe adjacent to the throttle body. All wires have been soldered into the ECU harness and no wires have been cut. I am also running the boost control function that came optional with the unit and am hoping to run between 16 and 18 psi. I am using Version 4.65.
Any help would be greatly appreciated.
Menus My Settings
Config
Vehicle Select 0
# of Cyl 6
Displ 3.00
Airfl Mode Speed Density
MAP Source GM 3 Bar
DENS Srce Use MAP
Baro Mode Sealevel
F Out Mode Supra MKIII
V Out 1 mde Use Setpoint
V Out2 Mde Use Setpoint
AFR Source 5V AEM Guage
F In Mode Supra MKIII
Aux 1 Mode Aux Trig Off
Setup
Mainscale -10.00
V Out1 Set 2.500
V Out2 Set 3.600
Afterstart 0.0
Lo Load Pt 36.4
Mid Load Pt 100.1
Hi Load Pt 143.0
Freq Out Max 0
Timing Mon Base 0.00
Timing Monitor Corr 1.27
AFR Tracking Delay 0.0
FE Smoothing 00
Use VE Table #1
Spk Base 0.0
Boost Control
TPS Spool 2.000
RPM Spool 2400
TPS Start 2.800
PSI Start 13.0
DC% Start 50.00
PSI Set 16.0
PSI Aux 14.0
Gain 10.0
DC % Start Aux 10.0
Max RPM 0
AFR Tracking
Min TPS 2.440
Min RPM 3488
Min MAP 148.2
Lean Lim% 5.0
Rich Lim% 25.0
Gain 4.0
AFR2000R 11.5
AFR3000R 11.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 -10.0 -10.0 -10.0
800 -10.0 -10.0 -10.0
1200 -10.0 -10.0 -10.0
1600 -8.0 -10.0 -10.0
2200 -8.0 -8.0 -10.0
2800 -5.0 -6.0 -8.0
3400 0.0 -6.0 -5.0
4000 0.0 -5.0 -5.0
4600 0.0 0.0 0.0
5200 0.0 0.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.00
TPS Delay 0.8
TPS Size 7
TPS MAP Max 104.0
MAP Enrich 0.2
Boost Enrich 0.4
MAP TPS Min 0.5
MAP RPM Min 640.00
MAF Limit TPS Threshold 0.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000 0.0 0.0
2500 0.0 0.0
3000 0.0 0.0
3500 0.0 0.0
4000 0.0 0.0
4500 0.0 0.0
5000 0.0 0.0
5500 0.0 0.0
6000 0.0 0.0
6500 0.0 0.0
7000 0.0 0.0
7500 0.0 0.0
8000 0.0 0.0
PT Tracking
Idle TPS 0.000
Idle RPM 640
Idle A/F 13.5
Cruise TPS 2.500
Cruise RPM 2560
Cruise MAP 91.0
Cruise A/F 13.5
Lean Delay 10.0
Gain 15.0
Lean A/F 16.0
Menus My Settings
Config
Vehicle Select 0
# of Cyl 6
Displ 3.00
MAP Source GM 3 Bar
DENS Srce Use MAP
Baro Mode Sealevel
Setup
Mainscale -10.00
V Out1 Set 2.500
V Out2 Set 3.600
Afterstart 0.0
Lo Load Pt 36.4
Mid Load Pt 100.1
Hi Load Pt 143.0
Freq Out Max 0
FE Smoothing 00
Use VE Table #1
Spk Base 0.0
Boost Control
TPS Spool 2.000
RPM Spool 2400
TPS Start 2.800
PSI Start 13.0
DC% Start 50.00
PSI Set 16.0
PSI Aux 14.0
Gain 10.0
DC % Start Aux 10.0
Max RPM 0
AFR Tracking
Min TPS 2.440
Min RPM 3488
Min MAP 148.2
Lean Lim% 5.0
Rich Lim% 25.0
Gain 4.0
AFR2000R 11.5
AFR3000R 11.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
2800 -5.0 -6.0 -8.0
3400 0.0 -6.0 -5.0
4000 0.0 -5.0 -5.0
4600 0.0 0.0 0.0
5200 0.0 0.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.00
TPS Delay 0.8
TPS Size 7
TPS MAP Max 104.0
MAP Enrich 0.2
Boost Enrich 0.4
MAP TPS Min 0.5
MAP RPM Min 640.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000 0.0 0.0
2500 0.0 0.0
3000 0.0 0.0
3500 0.0 0.0
4000 0.0 0.0
4500 0.0 0.0
5000 0.0 0.0
5500 0.0 0.0
6000 0.0 0.0
6500 0.0 0.0
7000 0.0 0.0
7500 0.0 0.0
8000 0.0 0.0
PT Tracking
Idle TPS 0.000
Idle RPM 640
Idle A/F 13.5
Cruise TPS 2.500
Cruise RPM 2560
Cruise MAP 91.0
Cruise A/F 13.5
Lean Delay 10.0
Gain 15.0
Lean A/F 16.0
