LPPRO's 2jz build!!!!! new shinny stuff!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
GeneStarWindGSW;900975 said:
Hey Guys :biglaugh:
Just get the Map-Ecu II ;)
actually i just bought one today, and wow you are back! after that one post i didnt think it was gonna happen Lol
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
a little update, i just bought a stock 2jzgte ffim to retro-fit onto my stock lower intake. (= yesss FFIM FINALLY!!!! lol i hate the side facing ones just a horrible design... other than that there isn't much going on until i get all the parts i have ordered in..
so do i need a safc if i have the maf-t pro? should i keep my safc?
lppro
Apr 21, 2007
895
ok a little up date a couple parts came in today,
oil drain and feed lines and fittings kit from xspower
cometic 2.5mm mhg
so heres my updated parts list
parts i have-
rc 550's
maf-t pro
wideband
MHG
head bolts
new water pump
new timing belt
new serpentine belt
new thermstat
rod bearings
piston rings
cam seals
1jz belhouseing
2jzgte intake manifold!!!!! (i have to adapt it...)
ss t4 exhaust manifold
ss DP
ss intake pipe
ss dump tube
1jz mounts
1jz oil pan
aromotive fpr
walbro
oil feed/drain
parts i need/am going to order-
driftmotion light weight 1jz flywheel
driftmotion stage 3 clutch kit
driftmotion t66 turbo
fmic
3" ic pipes and couplers
flywheel bolts
wastage (which one???)
air filter
2jzgte TB with TPs.... (i hope i can find one...)
there is probably more im forgetting about...
but anyways i thought ide update you guys with some progress.
oh and what should i use on the mhg? i was told by a few people to use copper spray, is this ok?
tlo86
Jul 24, 2005
3,914
Colorado
cometic 2.5mm mhg
parts i have-
rc 550's
maf-t pro
wideband
MHG
head bolts
new water pump
new timing belt
new serpentine belt
new thermstat
rod bearings
piston rings
cam seals
1jz belhouseing
ss DP
ss intake pipe
ss dump tube
1jz mounts
1jz oil pan
aromotive fpr
walbro
oil feed/drain
fmic
flywheel bolts
air filter
oh i remember when my list was this big!! :):) check out mine if you dont want to skip anything im going to update it right now
tlo86
Jul 24, 2005
3,914
Colorado
GeneStarWindGSW;903791 said:
Btw, i didn't see that small sentence about copper spray. Don't use it. K thx bye lol.
copper spray? for manifolds or something?
lppro
Apr 21, 2007
895
ive herd people say not to use it but ive had two very respectable mechanics tell me to use it, one has built many high horsepower 1j's and 2j's and the other has been a toyota mechanic for 20 years...
