LPPRO's 2jz build!!!!! new shinny stuff!
csnow
Matthew 6:33
Palm Bay, FL
lppro;883524 said:
also if anyone knows the part numbers for the 1jz bell-housing and flywheel form toyota it would be much appreciated.
thanks!
Just call Champion/Jay Mark's Toyota @ 800-327-2087 and ask for Jeff. He has all the info on the part numbers and he is the cheapest if you are buying new.
As far as the TB, I doubt you will outflow the stock one any time soon. Spent that money on ARP studs versus the stock head bolts that you stated you were going to use.
Chris
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
you'll be streching it with 3ft. You'd have to go directly over the valve covers and it still might not make it.
I think I used 4 or 5 feet.. I can't recall..
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
ok update,
i got the head rebuilt and resurfaced
the manifold came in today,
tore down the bottom end,
ordered piston rings, rod bearings, water pump, thermostat, head bolts, had gasket, timing belt, and serpentine belt.
also the 1jz belhouseing came in today but i didnt have any time to take any pics.
lppro
Apr 21, 2007
895
ya i got a little done.. no pics yet but i got the 1j bell-housing on the r154, also got about $550 worth of oem parts (timing belt, serp. belt, head bolts, water pump, speedo cable, cam seals, rod bearings, piston rings, thermostat, etc..)
i also ordered a walbro and a maf-t pro set up.
i do have one question should i keep my hks fcd? with the maf-t pro and safc do i need it?
