bigaaron;1175790 said:
That's a lot more money then just a simple inspection of the turbo, if it was causing a problem like this it would be obvious. Either the shaft wouldn't turn or the compressor or exhaust wheel would be damaged. I wish I could see it in person, we could probably figure it out in 10 minutes.
Yeah, it cost more, but I was wanting another turbo anyways and Vonda will be getting her a new one now.
IJ.;1175793 said:
J Told me he bypassed the Boost Controller plumbing the WG directly to a boost source and did the exact same thing.
Can't say I'm surprised that shimming the valve springs didn't help as 70 pounds seat pressure was adequate.
I have disconnected the avc-r and ran it on wastegate only and it does the same thing. I hooked the side port to the turbo and left the top port open on the wastegate.
Slow_Sc3;1175911 said:
try out an 18psi wastegate spring and see what happens since it looks like the 13psi wastegate spring is working just fine.
I still don't see how this will help Matt, but if I had an 18psi spring, I'd try it.
I'm going to buy a leak down tester and see what that tells me. I'm also going to recheck the compression on all cylinders and I"ll post up the results tomorrow. Hopefully I can get a leak down tester locally and see if that helps with anything.
List of things replaced so far:
wastegate
bov
turbo
intercooling pipes
couplings
tbolt clamps
vacuum lines
stinger standalone (I used George's and it did the same thing)
intake gasket
rebuilt the head........again
tried a different spring in wastegate (11#)
disconected exhaust and did a pull
checked intercooler for leaks
Did boost leak test numerous times
