Tire Shredder;1136792 said:Hey jay, I just read your whole thread! god damn! so much troubleshooting!
Now, I'll try and contribute at least something...I read that you're using pretty much all the same parts, excluding the intake manifold gasket. You've replaced many like the intercooler pipes etc. hoping that it's the problem. You've also checked parts individually like the intercooler.
Have you checked the system for boost leaks yet? I don't mean parts individually, I mean the whole system...as it sits, assembled? it could be something weird with a fitment angle or hanging stress on a part that allows a coupler or gasket to seal improperly when it's all together.
something like this should do the trick.
http://www.vfaq.com/mods/ICtester.html
as stated, forget the boost controller completely. until the waste gate is functioning properly on it's own, the boost controller is just another variable that you don't need...
suprahero;1136995 said:I need the extra 1500rpm to make me feel potent!!!!
Oh boy. That right there is gonna put a hurtin' on this here Hillbilly.ForcedTorque;1137038 said:So this thread is all about how you feel impotent?????????
suprahero;1136967 said:I've did this twice and I haven't found any leaks at all. How do you keep air from going through the intake and out the exhaust? I had to remove my downpipe and put a piece of metal like a gasket to seal it off. Am I doing something wrong? Wont' two valves be open at all times? This always confuses me, because I feel the air will just go out the valves and then out the exhaust. Someone please explain this, because unless I block off the downpipe, I can't pressurize my setup. Does this mean their is something wrong? Thanks Steve
I hooked the wastegate up to the turbo this evening and did a datalog. It's the exact same. It's hard to make me mad, but this is really starting to wear on me.
Tlo, I have a Garrett gt35r turbo with a T3 flange.
suprahero;1137652 said:I just did this AGAIN for about two hours. I didn't read your post until after I got through Justin. I unhooked the downpipe and put a piece of metal between the two to seal it off and then put twenty pounds of air through it. I don't know where it's leaking but it's leaking somewhere. It doesn't hold the air in it but for about one minute and then there's not a lot in there. I also took the Tial wastegate off and installed the spring out of my HKS wastegate into it and did another test run. It now spools to about fourteen and drops off to nine. I like this spring better so I'll leave it in for now.
I had my head completely rebuilt and I had them install some Crower springs and retainers. Could this be the problem as Justin mentioned. Should I hook the boost leak tester back up and see if turning the crank helps any? If I take the head off, will I be able to tell if they're leaking? I really want to get to the bottom of this. Thanks to all who are constantly checking in and offering advice. Keep the suggestions coming.
Turbo Drifter;1137675 said:One thing no one has asked is if the valves are shimmed right. If there not you may be holding the valves open a bit. Worth a shot.
Jeremy
