Lightweight hoods?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
what i did with my old hood was cut out all the bracing lighten up the hood a fair amonte and since it had factory cowl it was still stroung eghough to put 5 phone books on with out it sagging or bending down
weight was that of carbon hood maby tad heavy but it was free
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
I love my CF hood, WAAAAAAAAAAAAAAAAAY lighter than stock, my hood shocks had to be removed otherwise my CF hood would shoot up..!
I have hood pins, but I leave the latch for security/extra insurance...
NashMan
Aug 5, 2005
4,940
17
Victoria BC
plus it stops it form bowing with both in place
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
RoadRaceMK3;1260446 said:
Why only 235/255 widths on the RPF1s? I was thinking about getting those for my track car but I was going to try to squeeze much bigger tires on each. Also any pics with the RPF's?
And I saw this on suprastore but I have no idea about how much it weighs and how the fitment is:
http://www.suprastore.com/cafihofor87s.html
I've been running that tire size for classing (NASA is points based) and I'll be switching to RA-1's in a couple months. You can deffinitely fit more tire on them but I also like having as much wheel as possible (more control, IMO)
I'll see if I can find some pics to post, so far I hadn't run these on track as I was using my Volks on tires that are not as grippy as the Azenis so not many photo ops. I'll was using the RPF1s and Azenis just for auto-x stuff. They've changed some rules and I'm starting with 235/255 RA-1's but might be able to get 255/275 later in the year by removing a couple things (want to stay in the class for now)
Brian
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Does anyone know the weights on some of these hoods (VIS, etc?) I don't see this info listed and want to make sure any of these would be worthwhile.
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
My 2" Cowl CFX Hood weighs about 10-12lbs I believe. Here are a few pics when Bryan had it. It no longer has those hood pins....
-Mo
Mo87NA
8
Upstate NY
SupraOfDoom;1292296 said:
Ah you got it. Getting the corners fixed?
You know, they corners really weren't that bad. I just took a dremel and slightly sanded them down. If you knew nothing about these hoods, you really wouldn't be able to tell something was wrong.
Eventually I may end up fixing it, however, it's probably not worth it.
-Mo
figgie
Twin Cities, Minnesot-ah
SupraClaou;1258756 said:
What???
Stock hood goes for about 32 kgms + shocks :aigo: That's heavy
compared with my 9 kgm 'stoud' carbon hood ! :biglaugh:
32 kilos? No f'ing way the hood weighs 70 lbs. I know as I signle handedly picked up from my car.
40 tops and that is pushing it!
Dec 3, 2003
6,653
Canada
As I have said over and over, Gemini website aka Mark is a guy I have worked with when I ran CFX company and all Supra parts are mine along with many other design ideas, no matter, we no longer make the parts, period as ALL molds have been disposed of. (except a few that I kept for myself)
Weight of OEM hood is 47 pounds. Average CFX hood was 13-14 pounds. Ask me how I know. ;) They didn't require hood pins either although some like to run them.
Thanks
Duane
SupraOfDoom
Starcraft II ^^;;
Milwaukee, WI
-Mo
If you want a different hood let me know I'll take that one off your hands.
Mo87NA
8
Upstate NY
Will do. I doubt that will be happening but you never know. At least I know you'd be willing to pay what it's worth considering you did have an entire regulus kit :biglaugh:
-Mo
Edit: Thanks for the info. Duane. The hood really is gorgeous. I wish the previous owner had never driller it for hood pins, but I think I made it look decent ;) I'll post some pics up evetually.
By the way, do you know off hand how many 2" Cowl CF CFX hoods you produced?
Dec 3, 2003
6,653
Canada
-Mo
Less than 6 but would have to go through my files. (not gonna happen though:))
SupraOfDoom
Starcraft II ^^;;
Milwaukee, WI
-Mo
I "had" the Regulus kit. I also "had" a CFX 2" Cowl hood but in fiberglass. I also almost bought your hood before Slow66 even had it. Well let me know if you change your mind :p.
Thanks
Duane
One of the very few AM body parts I'd consider putting on a Mk3 :)
