Lifter Question...
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Scotch bright should do the trick. If it's at the top edge you could run like a flat head at an angle around the top where the burr is and flatten/scrape it off carefuly.
Just about any industrial tool supplier will stock them!
Also brilliant for dressing up a block and head after surfacing.
Wet sanding you need to be super fanatical about the clean up.
Still have to cleanup after a deburr but you're not producing the fine wet aluminium dust mixed with the water that sticks and gets into everything.
The tool makes long thin swarf that much easier to remove.
MA70witBoost
Registered Drifter
ok, thats what i was thinking.
gofastgeorge;1415887 said:
Try:
MSC industrial supply
http://www1.mscdirect.com/cgi/nnsrhm
McMaster-Carr
http://www.mcmaster.com/#
Others would be W.W. Grainger, KBC Tools, or any industrial, or machine ship supply.
Found several on MSC industrials page. any recommendations George?
suprarich
Guest
Nov 9, 2005
2,187
ohio
It would always be better if the head was off the block...But if you must do it while the head is on the block,,,,then it would be better to do it while a vac is pulling on the bore to catch flashing,,,then to do it without the vac.
