and fix by sanding down??nosechunks;1413704 said:Non interference motor stock, unless alot off mill work and a thin head gasket shouldn't be a problem.
Ive seen the valve spring compressor nick the top of the bucket bore and cause a slight dragging issue you described. look into the bore with a flashlight for anything that isn't smooth.
