Personally, if the gains are close to nill and the ecu is running on full out enrichment from the 5V's according to Vf, then I wouldn't bother with it until you had 550's so that headroom is indeed there
And i agree with you .... hence post #37starscream5000 said:He's pretty much maxing out the injector duty cycles on the 440's with that amount of power. Check out his A/F's, I'll pass on those, too lean for my tastes, I'll take 11.3-11.7's over his 12.?'s anyday.
Lucky.
A good rule of thumb would be 1cc of fuel per 1HP at about 80% duty cycle max on the HP you want to make on those injectors for that "headroom".
He has no headroom with that setup.
