I agree on both, this is not really stuff for general consumption. I just wanted to dispel the myths that it CAN'T be done.starscream5000 said:I'd also like to note that if anyone goes to and tries it, THEY DO SO AT THEIR OWN RISK! You have been warned. Some have blown their engines and it's been blamed on this, whether that is the case or not is hard to prove from setup to setup.
I would also suggest for them to send out their stock injectors to be cleaned and flow matched. There is a link in this tech section somewhere to a very cheap/reliable person that does this.
mkIIIman089 said:^See... we had something good going here, and then you go and do that.
SS5k: I think as long as you get a pump with more pressure capability you could easily bump the FP on a good condition set of stock injectors and be fine. I believe on the mailing list way back when this was referred to as the Lex/Hall mod.
I have read that webstie time and time ago but why the extra riskWayne G. said:I intend to run 550s and the lex AFM in my car, however some have had
good results without doing so. I refer to J. B. Lunsford website:
"I do not run the 550s on my car. I don't think they are necessary on a car with anything less than a full t04 turbo or bigger with more than 15 psi boost. This section is for information only.
You will need the following parts for the upgrade (this does not include the appropriate gauges and monitoring"
http://www.jblmk3.com/lexus.php
I never said it was b/c of anything specific I just said similar b/c he ended up boosting like 30something psi for whatever reasonstarscream5000 said:Are you sure the issue with Malloy's overboost was due to a mechanical malfunction of the BOSS turbo he had? I thought it was due to a FUBAR'd MBC. Something about the little check valve inside melting... :dunno:
But my point is ..... Stuff happens like failing parts so you should try to eliminate as much as you can. With the injectors maybe have more is better. I know the 440's can support a decent amount of power but adding the 550's leaves you more head room. Like I said I am stuck between the two for now.bountykilla0118 said:Remember a really good guy from the community had a similar mishap with his BOSS turbo and what less than 2 months later his motor ….. Ummm gave out on him. So shit happens .
