lets play a new game!
SupraMario
I think it was the google
The Farm
IJ. said:
We're only talking millivolts here Mario not enough to zap you but enough to cause an electolytic reaction in the motor and make it eat itself starting with the softer metals.
I've seen a brand new aluminium rad that leaked in 2 weeks due to this.
Holy shit, why do i feel like grabbing my multimeter and checking this now. Thats a scary thought.
Supracentral
10
I had this problem on one of my old [strike]MKII's[/strike] 1977 Celica GT's. Ate the living shit out of the radiator, water pump and head before I tracked it down.
Nasty problem.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Galvanic corrosion is a mean thing. I flooded my computer once, running a water cooling system with a copper / aluminum waterblock. Ate completely through 10mm of aluminum in a couple months. One of the reasons why I find copper head gaskets to be such a scary thought with our aluminum head!
Luckily computer gear is pretty waterproof by now, or I'd have had to replace a crapload of expensive 'puter parts.
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
Curious IJ, why do you say only an analog meter works for this?
I'm trying to picture why my Fluke wouldn't be able to measure it.
Nick: There's something in the filtering of a Digi that stops it working.
(Haven't tried the new Fluke yet just my old generic Digi)
I ended up finding a analog MM at a local electronics shop.
Piratetip
1,177
69
MKE, WI
Yeah my thoughts SC:
I just tested mine, 130mA on the fluke.
Something, but not significant.
Maybe I should drop a sacrificial anode in there.
Piratetip
1,177
69
MKE, WI
Simple, two dissimilar metals in contact either surface, through an electrolyte (coolant) or electrical conductor.
Piratetip
1,177
69
MKE, WI
Hmm, damn, way high. Not good.
I will have to locate an analog someplace.
Yeah this isn't an average MM.
SC: What did you come up with?
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
so i'm wondering if i forgot a little bit of info which may be needed
My overflow is now on the right side of the car and it's on a 45deg angle (i think 45deg) so on one side of the bottle it's quite full, on the other it's barely even starting on the low side lol
here's a pic, you can't really see the angle too much here but you can see the lid is down quite far from the top of that panel
http://www.supra.co.nz/rebuild/overflow.jpg
Here you can see the angle of the bracket, its supposed to be straight so you can get an idea of how much an angle it's on
http://www.supra.co.nz/rebuild/01102007/engine.jpg
SupraMario
The Farm
I think the whole siphon thing now applies more than the electical theory.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I'd be willing to bet that IJ is right about digi mm's not being able to properly measure this, because that's a way high reading.
On the other hand, I would have thought that the digi mm would give a low read or no read at all, and not a "high false" reading.
Hmmmm...better get your hands on an analog meter.
