Let's do a survey!
johnathan1
Supra =
Aug 19, 2005
5,056
Nick's "tuning" consists of keeping the car stock with a well-maintained cooling system.
Any # of things can cause BHG's...plugged radiator, stuck thermostat, bad rad cap, missing fan shroud, erroded water pump, weak fan clutch, sediment, leaks...I think the torque from Toyota was probably fine when all of the components in the cooling system were new, but now that the car is turning 20...we need a little extra insurance, hence the higher torque numbers.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Replaced stock HG with another stock type hg, ARP Studs to 81 ft lbs boost running around 10 psi just upped it to I'm guessing 12-13 psi...wish me luck.
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
johnathan1 said:
Yea, it should be 90 PSF (pounds per square foot)
Actually, the correct unit for torque is ft-lbs, because the calculation is T=r*F where r = radius distance between the pivot point and where force is applied (ft) and F is the force applied (lbs). PSF would mean that T = r/F. ;)
8,897
dav_dman said:
I'm not totally against rod knock. Lookin' for an excuse to cost justify tearing it down and building a 600hp car.
:thumbup:
Unfortunately, I don't think i'll get the opportunity, cuz the guy was career air force in california, always dealer serviced , syn oil, owners manual stamped. Car is in beautiful condition, new rad, alt, kyb's, interior perfect (until the heater core hose leaked on me). All reciepts, which is why i bought it. Btw, I wouldn't do half the service he did, or pay a dealer to do it, and i have an engineering degree. I have put syn gear oil with lsd additive etc in, and going with the lex mod.
That sounds like it is in good condition. Bad luck can happen though. And if the car is not repaired right, because you never know what that person actually did, then you will lose the head gasket again. I don't mean you personally, anybody.
You're being petty and coy, here , Nick. You have some knowledge to add to the forum in your thread, nobody's stopping you. We responded to your survey, now fess up your secret sauce, brother...what makes up Nick's "tuning" to avoid bhg running 58 ft-lbs with an alum head mounted to a cast iron block?
Easy, that composite headgasket is better than many think. That give that it has is intentional. That iron block and aluminum head moves at different rates as you are alluding too. I don't have an upgraded CT, or turbo. Yes, at 58 lb/ft, I think some people have lifted the head off the block on OEM original gaskets. With some loose headbolts from the heat cycles and abuse over the years. My car only has the HKS downpipe, and keeping it under 8 psi is a challenge, but the factory CT works very well there. The air isn't heated up very much at all. So am not running the risk of detonation.
SupraCentral said it best. Although, some people have only walked into the previous owners problems and didn't know it was coming.
No secret sauce here.
8,897
I believe lb/ft read; pound-feet is the correct term. While mathematically, there is no difference, it is only in how the force is being applied.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
These "stock hg is reliable" threads are like a support group for people who are scared they will get a bhg every time they drive, but they will not admit it, so they want someone to tell them it's going to be ok.
hehehehehe
johnathan1
Supra =
Aug 19, 2005
5,056
Haha...BHG's anonymous...lol...But I'll be the first one to admit that i am afraid of a BHG, even though I did everything right while replacing it (to my knowledge) and took every safety precaution I could...we'll just have to see what happens. :)
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
I'm with you there Jonathan!! I feel the same.. Should I install my 60-1 BB? Would it be ok to boost it around 15psi??
I took as much precaution as I knew.. Maybe it will hold up.. I guess we will see...
If not,, Then I will have an excuse for a total rebuild with forged internals. :naughty:
oscar35783
195
Jax, FL
hehehehehe
So true. The only time I don't think about it is when I have some jackass in a Honda reving his engine next to me wanting to race. So I'm like come on, let's go. The gasket will hold. LOL.
mhopemk3
Jul 13, 2005
762
Oscar,
It's going to be OK!
oscar35783
195
Jax, FL
Hello, my name is Oscar and I have a fears of BHG. Thank you for your support and understanding. LOL.
Oldsupraman
14
Northern California
oscar35783 said:
I want to do a survey on the people who is running on stock headgasket and retorqued to 70lbs or higher. How many psi are you running right now? If you did have a BHG, what psi did it blow at? I am not referring to people who have BHG and running stock gasket with stock torque 56lbs or MHG.
I blew a stock headgasket recently after rebuilding the head. Head surface looked good. Block surface was kind of pitted in one spot. ARPS torqued to 75 ft-lbs. Well tuned. It lasted about three months of easy use before blowing right where the block deck was questionnable.
I knew I was taking a chance on that block. There are limits to what torquing down on a rough block can accomplish. That's why I am about to rebuild the engine with a MHG.
