Leaky hatch? Look here!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The nuts are on the underside. Pardon the pun.
- Remove the two hatch cover hooks
- Pull the plastic cover off the bottom of the hatch
- Inside, where the wiper motor / rear window defog connections are, you'll see four nuts.
HKS_TRD
998
Australia
One other thing I noticed in that area when I pulled my car apart is that in the channel under that black trim piece there are a few little plastic clips that kind of act as guides for where the hatch glass is meant to go I think, but either way regardless of their purpose these clips just push into a hole in the hatch and would be another potential source for a leak
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Those are blind holes on my car - they don't go all the way through to the inside.
HKS_TRD
998
Australia
Oh OK
I will have to have a closer look on mine when I get a chance, I was trying to decide what to do about those
Does the lower trim have any form of seal from the factory when you buy a new trim?
CPT Furious
Now MAJ FURY!
KDOV
I know it's a little old, but still really good info here.
Grim, are these bolts the four that run across the bottom, underneath the glass? If so, what exactly separates? I don't have my deep well sockets right now to figure it out... :(
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
HKS_TRD;1663523 said:
Oh OK
Yes, the new one comes with little foam seals around the base of all the bolts.
That's correct - and all they hold on is the bottom piece of window trim, they don't have anything to do with the glass itself.
