Hi Guys
So I need some urgent help. Ive installed my new turbo , took me quite some time to remove the old one and fit the new one back in , but now when I start the car oil pours from the actual fitting from the block to the turbo oil line.
I used this kit :
http://www.ebay.com.au/itm/270947047694?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
The flange itself is triangular shaped with two holes that slots on to the block. Ive tightened the turbo oil line fitting and those two nuts on either side but its still leaking. It doesn't drip it literally gushes out. Even if I didn't tighten the oil line properly it should leak not pour oil.
-Why could this be?
-Is it possible I could of cross threaded causing a leak?
-Is this a common problem with the 7m
Its really difficult to get to since the turbo is now installed(and im certainly not removing the turbo again as it took me hours to put back on),so its taken me hours to tighten.
Help please , just did a whole slew of mods so my car has been off the road for the past month and this is the only thing holding it back.
Thanks in advance
I used this kit :
-Why could this be?
Thanks in advance
