Lamarossa Flush Headlights In Progress
LamaRossa
One and Only LamaRossa
Apr 6, 2005
131
ct
got sick of the pop up headlights made out of fog lights
hardly light up the road at night
bought some real hella 90mm headlight modual
total so far $273
mad work ahead
spring time is going to be looking sick
lamarossa- im gonna be around forever hahahah
got any pic of the set up
please post
UPDATE
after a trip to home depot
+ $20
just bits and pieces
there is hope for this set up
i might have to relocate the battery and say good buy to the windshield washer filler neck
to be continue............................................................
driver side has the battery in the way so because of the low beam projector is so long it will not fit and clear the bumper therefore it must be mounted on the inside in stead of the outside.
by cuttting the radiator wall support, you can get a good beam pattern by raising the rear of the light all the way up until it hits the hood line. But this also means that you have to reweld the wall with supports to keep the front end from rattlling.
noxide
173
conroe
www.noxide.com
hey this pic may help. Im thinking about re doing my tails and this was the original idea that i had when i first bought the car. Sorta ferrari like.
noxide
173
conroe
www.noxide.com
oh and sorry to get off topic but here are some pics of a supra that could give you more ideas for your car. The tails off of the 300zx are the ones im going to mold in. $175 on ebay.
Dziuggy
eurotrash
san francisco, ca
dziuggy.com
noxide and lamarosa should work on one car together so only one supra would be destroed in the end.
and lam i doubt that 90mm hellas will light anything if mouted flush (non raised) most completely flush lights use thin lights that allows mounting them higher to clear header panel, so it will not drop a shadow
shaeff
Kurt is FTMFW x2!!!!
10
Around
keep this clean. i dont want to have to lock this thread. consider this a warning before anything gets blown out of proportion. if you have nothing nice to say, then dont say anything at all. i've been itching to use this ban stick... ;)
-shaeff
mdr40z
arkansas
lam, could you be the first to try hinging the headlights the other way? to raise in the back instead of the front? there is plenty of room to put whatever beam in you like, I've always thought this would be a good way to do it.
-shaeff
com'n shaeff, I been dying to use this......
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
ts_MKIII said:
how hard is it to make stationary head lights and how do i do it?? cuz i want some stronger bulbs.
Build this to the exact size of the headlight. Mke a clear plastic cover that is the exact same size to cover it up. Your done............ :biglaugh:
