ks racing ffim
survyor2
171
West Palm Beach, Florida, United States
MY REVIEW OF KSRACING INTAKE MANIFOLDS FOR 7MGTE
I have this FFIM installed now. It does take modification to fit this monster of an intake. The plenum sits low in the engine bay because the runners are not curved and perpendicular to the head. Here is what I needed to do to get it to fit.
- It hits the brake booster. I assume this is because the builder is not farmilar with left hand drive setups. I was pretty upset at first but this isn't that bad of a fix. I just cut off the back corner of the plenum and had an aluminum plate welded to the cut out. It actually turned out very nice looking and shouldn't effect flow. The welds were ground down and polished. The welder had to remove the anodization but it polished up nicely afterwards.
- It hits the alternator in the stock location even though I was told it clears the alternator. It hits the alternator WITH a relocation bracket. That was upsetting at first too but I figured that out also. With the relocation bracket (thanks Brent) that Sethron sells I can pull the alternator directly against the block but this still isn't enough room. What I needed to do is cut the tabs off of the aluminum timing plate cover. Those two tabs hold the plastic timing gear cover in place but there are enough bolts in other places for it to not be an issue. The plastic tabs must be cut off of the timing gear plate also. I used the smallest possible alternator belt. I have the part number and will post later. The auto parts store sells them in 1/4" increments. Now the alternator fits but the stock tensioner bracket is no were close to fitting. I modified the stock bracket so its much shorter. Just cut it up and drilled a new mounting hole. With the new tensioner and a short belt the alterantor sits 1/4" off the block with the belt tight. And yes, I kept the A/C!
REVISED: A/C BELT WAS OUT OF ALIGNMENT. A/C COMPRESSOR WAS REMOVED AND ALTERNATOR WAS LOWERED WITH BRACKET.
-The flange has a hole for the coolant to flow to the TB and ICV. It is not a nipple. If you need it, welded a nipple on or do like I did and weld it shut.
- The Q45 throttle body will touch the body of the engine bay just forward of the drivers side strut tower. This is a big problem especially if you have rubber engine mounts. Mine are solid and it was too close for comfort for me. I used a big hammer to push in the body to get 1/2" clearance for the TB.
-This intake manifold does not include a throttle cable mounting bracket. I got one from Sethron for $25 shipped and had it welded on. I used a $3.50 throttle body cable from a 1995 Camry at the junk yard and its plenty long enough.
-You need to relocate the fuse box, ICV, ignitor, resistor and battery. The ICV, ignitor and resister barely fit, but fit under the plenum. Alot of wires had to be cut and extended because the main run of the wiring harness sits much lower under the runners.
-The flange is much thicker than the stock flange. I needed new M8-1.25x30mm bolts to mount it to the head.
-Of course you will need new piping from the intercooler to the throttle body. I ran 3" from the top of the driver side of my 24"x12"x3" intercooler, under the headlight and to the TB. I installed my blow off valve flange, GM intake temperature sensor, and ICV source port on the piping. I used a 3" 90degree, 3"45 degree and 3" to 3.5" couplers. Running these under the STOCK headlights might not work, my headlights don't go down as much so I have more clearance.
So now it fits and i have 1/8" to 1/2" clearance between the brake booster, alternator, strut tower, TB, and brake booster. Very tight fit, but it fits. This might be a lot of trouble to go through for some people but it was a challenge for me and I was determined.
This is what I ordered: left hand drive, no alternator relocation, ICV flange on bottom, Q45 TB flange, 3 small vacuum ports, 2 large vacuum ports, polished for $475 shipped.
Will post pictures soon.
Dennis
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
it seems cheap at first hand but for all that modifications i don't think it is worth the price. When anyone can find it on the forum for around 4-600 with everything. I might be wrong but it has popped up once in a while. Some one was selling a 2jz manifold mated to a 7m for 300. I haven't seen pictures of the Thailand manifold, i have nothing against it but for what Survyor had to do, i don't think it is worth the price at all. I'm waiting to see how nice this piece look.
survyor2
171
Hits brake booster:
Cut rear corner:
Final:
Still need some install pictures.
survyor2
171
I agree with that. Its not going to be the cheapest in the end. Someone with welding skills wouldn't have a problem fixing everything that needs to be fixed. One major benifit is the contoured style of the intake. Its my personal preference and I don't know of any other ones out there except the other ebay one for $990. Maybe there are others, I just don't know of them.
I need get get some good pictures of this fully installed. It definetely looks nice. I thought I had some pictures, but I guess not.
Dennis
suprafredde
160
South of sweden
Did you tell the seller about your problems?
If he would fix the brake booster clearance and maybe angle it more upwards so the alternator would fit with a drop down bracket he could probably sell a LOT of these.
suprafredde
mytmk3
643
christchurch
I think I might buy one of these this week to try on my rhd car :) just waiting to hear back about shipping. also if you noticed he has a us spaec listed now too
mytmk3
643
christchurch
well mine arrived yesterday the alternator brackets a nice idea but thats about it positions it infront of the turbo and the brackets foul on coolant sensor plugs not to mention im sure it would wobble all over the show.
the manifold is........ average? visualy it looks ok I dont think its going to foul on end on anything in the engine bay I say think because the mounting holes are a tiny bit off by the studs so it will need to be given a little trim.
will put up photos later once I find my camera
nerfkhat
168
centennial, Co
Yea thailand has a shit ton of supras there. They problably one of the top modders for 2jz's. Ive seen them stick 2jz's in everything all custom built too. But just cuz its from thailand dont mean its crap. They have do good work there too.
mytmk3
643
christchurch
hvyman;1537125 said:
So you put the alt where the the p/s pump was instead of just a drop down bracket?
yea I used one of wes beaches alt relocation brackets Im not 100% sure but the alternator might still be in the way with a drop down bracket. This thing is not perfect and people on here make better ones im sure But with little time on it it worked
mytmk3
643
christchurch
survyor2;1537553 said:
wtf? you replaced the whole flanged because it was warped? same happened to me. simple table sander at the local machine shop used to make it flat again (just like it says to do in my review). Just a few dollars.
the people building my car rung me up and said it doesn't fit(I already knew this when I tryed to fit it) and told me my best option was for them to cut off the flange off my stock one and swap it to which I replyed do it then wont get far without it was there a cheaper option??? more than likely this was the one I was given I just want to drive my car so I said fuck it.
I dont know the extent of the damage to the flange but you couldn't even get it on the stud they were a few mm out from one end to the other. yours may not have been as bad maybe or I may have been given poor advice moot point its done now anyway
robhojy
swazzy,land
on a right hand drive car:
sorry this wont be much use for reference to you Left hookers. the plenum itself is very well made, the man at KS racing is a top bloke, very good comms and is speedy to reply on messsages, and for the price a good manifold, cost me £300 delivered. the welding on the manifold is porno
