knock knock!!
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
had a quick question.....i have a knock in my motor.....i only hear it at abouy 2-3800 rpm.....if it was rod knock it would knock all the time right? could i be a valve?
AJ'S 88NA
2,419
Florida
Probably rod knock. Better check it before it gets any worse. Mine let loose and scored the cylinder pretty bad. Had to bore over 60 to take care of it:naughty:
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
rod knock starts out as only being able to hear it right in the RPM range you described
Rod Knock :(
