Just how much does your subframe move?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
you know what i find funny that is normale
installed new bushing on buddies car same affect
that just how they are there floating sub frame i find
once spacer is use or other it stops the float but you get responcive ride but rougher
thus it's luxorey car and that how they are
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
I plan to run polyurethane bushings but I'm still not 100% sure on if I should run spacers.Dose it sound like a good combo?or would the poly bushings just be enuff.I'm build my car for track racing so I am looking for a more responsive car.
Fuzz420
Are U Here 2 take My Baby
I dd my with hopes of someday going around a track. I used poly bushings all around and nylon subframe spacers. I dont have anything to compare it to but it feels good IMO
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i whould not worrie once you have the polly in solves most of the issues
there is still the upper spacer's if there not rusted to shit then you should be ok
at this point the bic will be your only good call since the spacer idea if done right will not work with polly since you need to strech the stock rubber for it to work right
i was from what i can remmber i am the frist person to do this long ago
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
Who the hell wants a spacer made out of nylon honstley? They wont last forever. Nylon is used for bushing's and things that need to be able to slide and move. Dose that not defeat the whole porpus of these bushing's?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
with polly bushing in place not a stock rubber one
spacer are thicker cause you have to pull on the center race to tuch the body of the car the lower washer now will be sucked up pinching the sub frame this maken soild monte
no more float
he has polly witch has not much for movement bic sub frame bushing are factory replament but alot more solid then the stock flex bs
his spacers on stock rubber monte will be more of plush ride and take away so move ment not all thou but some
me my self i just use spacers cause i am not a sissy
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Lets not bring porpoises into this, no need to talk about dolphins' cousins.
From my experience, hard Nylon will last forever and serves the purpose pretty well. Maybe not forever but I havn't lived that long yet. They give a tiny bit and might not be quite as harsh as metal spacers but still do the job WAY better than stock.
grimreaper
2,180
Dallas
i just re did the tq on all of them and was quite surprised. Even ones that took a 3' breaker bar to loosen were in the 70-80 ft lb range. Feels like a sports car instead of a camry on the turns now, well worth the hour to check them all
good pointer poodles!
The difference is HUGE with the targa off when I did mine...
Personally I'd never run solid subframe mounts/spacers as then you're going to hear the suspension and especially the diff.
Poly is about as far as I would go, same with the rest of the bushings...
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
I just retorqued mine with 197k on the clock. They weren't that loose but definitely weren't at the proper torque. Haven't had a chance to drive it yet.
1-2clutch-u
379
chi town and ohio
WOW look what I started. lol. I wont lie Im soo lost wes or any other vendor I would like to fix mine. I will be tracking my car but I is still a daily driver. What do I need to buy? I got $100 in pay pal right now just let me know. also I dont think I would like to take the whole sub frame off the car but I will if needed but just let me know. thank you.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
With mine it did not have anymore road or suspension noise than normal. I dono if other people got alot of noise tough.
grimreaper
2,180
Dallas
noise, NO. The car feels a LOT tighter now. the body roll from quick turns of the wheel is 100% improved. Think camry turn in, body roll and steering turn in to a corvettes. Mine were looser then they should have been, results may differ....
