Just fired up new motor.. !!HELP!!
johnathan1
Supra =
Aug 19, 2005
5,056
suprapower1221 said:
You need more fluid. It takes around 12 quarts or until the tranny fluid is all the way to the top of the dipstick tube. Without the fluid you wont go anywhere. Hope this will help out.
Oh yea i almost forgot make sure it 90w gear oil.
WTF?? Why are you helping him?
Although, that info was easily found if searched for... so nevermind.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
I don't really nkow what is going on but to screw someone from here and then turn around and ask for assistance seems to be about like shooting yourself in the pecker and then asking how to reattach it. I would deffinatly fix what you have wronged before asking anything else. Otherwise expect to have many threads of flaming.
suprapower1221
80
pa
You might want to check to see if you put your motor mounts on because if not the motor will spin upside down and go in circles instead of the tranny moving. I have seen this with many people installing trannys. Make sure you keep your hands out of the engine bay while the motor is spining around or its like a blender :3d_frown:
suprapower1221
80
pa
It is if you can shut it off at the right time and it stays upside down. If you try pouring while the motor is spinning you will have a tie dyed shirt with all of them oil stains.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
That is why you buy a button to bump it over. It helps when it just won't stop where you want it. Maybe he could sell the shirts to pay someone to fix his car
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
bah, you guys are all retards. i cant believe youve never put a tranny in before!
heres what you do:
strip the interior (yes, even the carpet)
bust out the sawzall and cut a large hole in the floor around the tranny
use aforementioned sawzall to finish cutting transmission out
find new tranny (gearing from an 18 speed bike should fit, but if you want the extra power in the 1/4 mile definitely go for the 21 speed jdm bike)
kick back, take a gallon jug of bleach, pour some in a glass and drink the remaining bleach in the jug.
have fun!
suprapower1221
80
pa
:yelrotflm lmao He just needs to spend more time reading and less time :wuteva: Because if he cant do the tranny install you know he spends to much to playing with him self instead of searching up info. I agree with clip on the bleach. Once you drink the rest of the jug you wont believe how fast time flies while doing the Tranny install. Be a man and use the funnel that you were putting the oil into your car while your motor was upside down to finish off the jug of bleach. Sorta like a beer bong.
suprapower1221
80
pa
Porterzsupra you should let us know how your tranny finally turned out in the end. Hopefully he does get back to us even after he drinks the bleach/paint thinner.
