Hi guys.. and gals - if any.
I just got my car last weekend and have a couple of quick questions (yes I did search)
1. What is the light on the very left that came on my dash for ten seconds that looks like a bird cage and then went off.. I mean a bird cage.. wierd.
2. I am running a canadian car so my oil pressure guage is in cm2 and it sits at approx 2.2 when driving on the hwy (not accelerating - keeping steady. Is this ok? or is it low.. (by the way I went to Toyota tonight in Richmond and they were closed so I will have to get a manual - did not come with the car)
3. I do have the knock on the pass side, near the back of the engine below where you can see - almost like a header was loose or broken - (may not be the engine) cannot hear it after 3000 rpm - loud at idle (I have searched but the answers vary widely- I did intend to spend money on this car.. got it for cheap..)
4. Passenger doors are all closed and the red door light on the dash flickers a lot all the time.. nuts - need a fix.
5. My glow ring key thing keeps coming on and off (only at night when lights are on)- be best to disconnect it. - not sure how.
6. The orange check engine light is on as soon as I go above 2g for the very first time and stays on for the rest of the trip.. I do have to hit Toyota to find out what it is..
7. What is the lock out overdrive switch for -(upper right forward on the floor console) I can turn on or off my overdrive on the auto stickshift
Thanks in advance for any advice.. I have over 300 posts on the jeep forum so I will be around here for quite a bit..
