sarichmond said:Outstanding!!!!!!!!!!!!!!!
Will you be going to vegas this year?
If it gets done and if it's running right by then, yes.
--Ron
Overboost protection I assume? The vacuum regulator, does it have to be plumbed with a vacuum line or is it a self contained unit? Also, do you ditch the catch can setup? I've been told about vacuum valves, but I've never seen one so I'm very interested. I've been told (by a friend that used one; ie first hand info) that gains of 30 hp are common. In fairness, he was running 12.5:1 CR, so I'm sure that caused more blow by, but turbo's do increase the CR, too.jt2ma71 said:I may also put a pop-off valve on the intake manifold, not sure yet. Ron.
rakkasan said:Overboost protection I assume? The vacuum regulator, does it have to be plumbed with a vacuum line or is it a self contained unit? Also, do you ditch the catch can setup? I've been told about vacuum valves, but I've never seen one so I'm very interested. I've been told (by a friend that used one; ie first hand info) that gains of 30 hp are common. In fairness, he was running 12.5:1 CR, so I'm sure that caused more blow by, but turbo's do increase the CR, too.
Will you share what the valve cost you?
jt2ma71 said:Thanks for the comments guys. Mark, the valve is a standalone unit. The dry sump oil pump is also the vacuum pump in this setup. The vacuum valve is of course adjustable to limit the vacuum to the optimum setting. It just leaks when it reaches the desired vacuum (like the pop-off valve for pressure)
You also don't want to run too much vacuum because it will cause oil starvation on the wrist pins that are not oil fed, my 7m had pressurized oil to the wirst pins via rifle drill through the rod beam, I have not seen this on any other rods, especially H-beams. The valve is ~120 dollars but there are cheaper simpler looking ones from Moroso.
--Ron
They are Cunningham rods and the rifle drilling was an option. Ronsiman said:Wow ron! I did not know your 7m's rods ( pauter or corrilo?) were rifled! Was that done on your part or did they come automatically like that?:icon_conf
-Jonathan
group a supra said:ron can you do me some clearer more detailed shots of the porting please i would appreciate it as everyones stage 3 is different and wanted to see how it compares to mine that i did![]()
jt2ma71 said:
rakkasan said:Damn Ron, that's the nice porting job I've ever seen.
