Coated wiseco's for my 7M. I would go 2jz if I aquired free things as well. Soon I will be buying a FFIM for my 7m off ya!
jt2ma71 said:Oh yeah, the 7m/setup is up to PAR, even though I have not pushed it to its limits yet.
I just want to try the 2J. Acquiring 2 free shortblocks is really what started this whole thing.
cwapface said:Can I park my supra in your driveway? I'm pretty sure it would get faster by osmosis
aljordan said:Should be crazy in a 280Z. Since that's what you're doing.
Yeah, this is just something to do while waiting on something else to dochevyeater said:Don't sweat the oil pump too much on a 2J. The front seal should be screwed in though to hold it down for good (drill & tap around the outside and install some bolts and washers to retain it from the front, just make sure they are low profile to clear the reluctor and sealed against leaks).
IJ. said:Steve: Nope not at all, ours seals crankcase pressure the 2J seals Oil Pressure as the pump is behind there!
jt2ma71 said:Yeah, this is just something to do while waiting on something else to do
Do you know how much clearance there is between the face of the seal and the back of the timing gear? less than .25 icnch?
Ron
