As you may remember, I opted to route my engine harness through my speedometer cable hole. I never did like cable driven speedometers, at least since electronic ones were around. I've been trying to figure a solution to an electronic speedometer for the Supra.
I went to the junkyard yesterday and scored a Gen 3 Camry gauge cluster for $15, steering rack heat shield for free, and a VSS from a V6 4-Runner for $4.
I'm pleased to say the R150F VSS fits perfectly in the R154 and even had the right tooth count for JZA70 4.10:1 gears since the factory 4-Runner gears are 4.10:1 as well.
R154 speedo cable drive on the left and R150F VSS on the right:
Installed:
Wiring up the Camry cluster to the VSS and getting it functioning on the bench was cake. Just need to get it working in the Supra cluster with the Supra gauge face.
Goodbye archaic cable driven speedometer!
Installed:
