JDM 7m-gte
Status
Not open for further replies.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
bountykilla0118 said:
Does anyone else think that 3000 for stock rebuild is waaayyyy to much .... or am i the one that is off?? From what i remember ........
MHG -$200
Gasket Kit $200
Piston Rings 70
Oil Pump $150-200
Rod Bearings- $30-50
Main Bearings $40-60
Arp head bolts $100
Valves 3 angle w new stems $300
Have block resurfaced $60
Head Resurfaced $60
And to be on the safe side ..... 1500 bucks
If you install new rings without honing the cylinders you are asking for trouble.
Same thing goes with installing new rod bearings without resizing the rods.
ARP rod bolts are a good idea to install before you resize the rods.
New bearings without at least polishing the crank is something you should probably not do.
The pistons will need to be cleaned and checked, as they will probably have carbon buildup on them.
A $300 head rebuild may not include the valve adjustment afterwards.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Those things come standard to me i should have stated that :nono: mybad ..... thats why i feel $1500 is good bet but not $3000 add $150 or so to polish the crank but it could be more or less depending on the person who is doing it and around $75 to hone the block
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
TurboWarrior said:
I wish i could have done everything myself but i don't have the tools, time, or space to disassemble the block myself. You got me interested in my grand total now... Ill let you know.
When dealing with anything you should alway check things out yourself first shop around to get an idea of what things cost and how/why they function. Sometimes well most of the times its almost cheaper to buy a part yourself vs having the mechanic buy it ..... since most are trying to make a profit off of parts and labor
TurboWarrior
Canada
Yes he does make a profit on his parts. But I didn't want aftermarket so i bought my own toyota parts and brought them to him. Little did I realize he now won't warranty the motor because there not his parts because he did not make money on them. He should have told me that before I didn't know he even cared.
I got quotes from other places. another place was $3200cdn full motor rebuild. Thats using all toyota parts but stock HG and head bolts. I wouldn't have had to buy the parts that way but it would have been a little much after buying the mhg and arps. They were all in the same ball park
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
CDN? Whats the conversion rate to dollars? Well with forged internals and a rate of $75 h/r or whatever they charge for the labor i can see that price 1500 for rebuild stuff + 1200forged stuff + 700 labor
TurboWarrior
Canada
3,200.00 CAD = 2,813.42 USD
Before I speculate too much ill get a total like I said hopefully tonight and compare. $1500 + $700us labour is getting more realistic. But there is always that extra stuff that puts it over the edge. I mean I needed a timing belt tensioner or watever. It was $150cdn!!!!! just for that. with a 15% discount.
againstdawall06
298
mo
for me that included new pistons, rings, rods, crank.
MHG -$200
Gasket Kit $200
Piston Rings 70
Oil Pump $150-200
Arp head bolts $100
Head Resurfaced $60
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
ill tell you what, sicne my currrent car which came with the knock, i bought a longblock fro ma guy i knew, it has a JDm head, no EGR yadda yadda yadda, no sludge deposits, cylinder walls looks like thevye JUST been honed (im still gettign it rehoned and new rings, it came with a MHG on it, bottom end is probably solid as well. But i am still rebuilding it. Why you ask? Because the car sat through 50,000 km's already so why not refreshen it so it lasts a lifetime? And plus all the parts i got were off members and misc peopel and i think my rebuild cost with everythign i need minus rod bearings is a little over 400 usd. Hone + resurface block(if i need it, maybe just a lap) and resurfaced head will put me in the cost of a JDM 7mgte shipped otmy door. and this will have allbrand new hoses, gaskets and everythign needed to make my car relaibel as hell. and considerign i onyl drive about 10 kms a day, + winter store it, this motor is gonna last a loong, loong time.
TurboWarrior
Canada
Total cost of labour was $1750cdn.
Head Rebuild/Machining/Hot Tank
Block Rebuild/Machining/Hot Tank
Crank Polish
Frost Plugs
Cams Reworked I think. Something was done to them anyway
Piston rings were included in this
Head installed onto motor and torqued to 88ft/lbs
Flywheel Machined
Toyota Parts:
Main/Rod Bearings: $230
Thrust Bearings: $60 I think
Toyota Complete Engine Gasket Kit $400
Waterpump $70
Toyota Exhaust Studs/Nuts set $30
Turbo to Exhaust Gasket: $45
Toyota Timing Idler Pulley $150
Timing belt is part of these prices
$985 in parts directly involved in rebuild
TOTAL SPENT FOR MACHINE SHOP REBUILD $2935
ARPs $120
Titan 2.0mm HG: $320
$3175 Total spent on Engine Rebuild
Other Parts: Not a complete list
Toyota Hoses: $200
Complete clutch $500
Power Steering Pressure Line $175
Power Steering Rack Rubber Insulators $50
So there you go!!!!
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
after all this i am like whatever man ::dead horse:: if you think that was the best deal you could get i would love to sell you a jdm 7mgte for which should normally cost 900-1000 for 1500 it only has "30,000-60,000 miles" :evildeal: i promise ...............
Crank Polish
Frost Plugs
Flywheel Machined
Toyota Parts:
Waterpump $70
Toyota Hoses: $200
$1185 directly involved in rebuild
ARPs $120
$3375 Total spent on Engine Rebuild
So there you go!!!!
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
I was waiting for someone to step to the plate and say what they spent on a stock rebuild ......
Justin727
T-virus infected
i wish i could go back in time. I bought a JDM motor and ran on it for a lil over a year and had not 1 problem with the motor. I got bored with it drove it to the back and pulled it out. I was going to rebuild it. but i decided to rebuild the usdm original motor. If i would have done that I'd still be driving my supra right now. O well we live we learn. Only thing different was my jdm 7mgte didnt have oil squirters. No big deal at all. agian it was a great JDM motor
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
Mine had a spun bearing when I bought it. So far I've spent (just on engine):
(all Canadian $$):
850 - all machining (hottanking, boring, honing, rods resized, etc)
650 - gasket kit, exhaust helicoil kit, Titan mhg, Main & rod Arp's, oil pump
150 - head Arp's
965 - forged Ross pistons
+ lotsa hours cleaning, polishing and porting, etc.
When you buy a Supra, be prepared to spend big if you want it right!
Justin727
T-virus infected
(all Canadian $$):
150 - head Arp's
wow someone butt raped ya!
well atleast its done right!
Status
