Alright guys, cat's out of the bag. Since about march of '11, i've been calculating and experimenting with different coilovers for the mkiii supra. reason for this: there's no coilover there that i was really happy with... stance coilovers clunks, teins were to high, ksports were to soft, Megan's didnt go low enough. any other coilover was pretty much just a restamped coilover or an alteration. So i took my numbers with dan, the shop owner. told him what was needed for it to bolt up, after the 2 months wait from japan, we got the first set done. everything bolted on like a glove. the only issue was that i couldn't go lower in the rear, the bottom mount and damper was too long. in order for me to go lower, was to remove collars or to remove the secondary top perch. i didnt want to remove the second perch though because that would defeat the purpose of the pillow ball mount. So with the rough start on this set, we made adjustments and made a new model...
the new coilovers utilizes shorter rear dampers and shorter bottom mounts so people can really slam their supras.
12 clicks of dampening adjustability
18kg F, and 12kg R spring rates.
the goal for these coilovers is to get lower than any other coilover can offer without harming the preload, and a dampening system with the correct valving and quality you can trust.
Now being this low brings upon other issues. like extremely bent up suspension arms, and for me, hitting my axles against my subframe.
As a result you can anticipate good parts coming in, such as adjustable suspension arms, sub frame riser bushings, and a steering knuckle mod.
*NOTE* I am in no way affiliated with Part Shop Max other than a customer, and friend. I am not advertising these for sale, and I am not selling them.
