jdmk3_87t said:
OMG...I just found the nicest pre89 burgandy supra...Where have you beeen all this time?!?! I really wish my car would loook just like your car one day. Try to list the mods you have on the car whenever you can. I'm digging everything on there!
Modifications that have been performed to my 1988 Toyota Supra
· HKS Full Turbo System
System includes Garret T04B 57 Trim Turbo
HKS Exhaust Manifold and Down Pipe with External Waste Gate
HKS F-Con Fuel Computer
3mm Steel Head Gasket
440cc Toyota injectors
· HKS Intercooler Kit which includes all piping
· HKS Super Sequential Blow Off Valve
· Cooleeze Custom made Intake Pipe
· HKS Power Flow Intake
· Modified AFM
· RC Engineering modified Throttle Body
· Edelbrock Water Injection kit
· HKS Oil Cooler Kit
· Horsepower Freaks Goliath Exhaust System
· Sun Auto Hyper Ground and Hyper Voltage Systems
· MSD 6A Ignition Box and Ignition Cables
· HKS Super Fire Iridium Spark Plugs
· HKS EVCIII with ATM Electronic Boost Controller
· HKS Turbo Timer
· Optima Red Top Battery relocated to spare tire well
· HKS 13lb. Chrome Moly Flywheel
· Center Force Custom DFX Clutch and Pressure Plate
· Custom Made Stainless Clutch Line
· Drive Shaft Shop Aluminum 1 piece Drive Shaft
· C’s Shifter with Razo Carbon Fiber Shift Knob
· HKS Hipermax Coilovers
· Suspension Techniques front and rear Sway Bars
· A-1 Racing adjustable Sway Bar End links
· A-1 Racing Traction Arms, Toe Rods and Camber Rods
· Greddy front and Cusco rear Strut Bars
· JIC Magic Lower Control Arm Tie Bar
· Jim King Front Brake Kit to include 4 Piston Wilwood Forged Billet Superlite Calipers and 13.1x1.25 drilled and slotted 2 piece rotors
· Precision Brakes Co. Rear Brake Kit to include 4 Piston Wilwood Forged Billet Dynalite Calipers and 12.8x.81 drilled and slotted 2 piece rotors
· Custom made Techna-Fit Stainless Steel Brake Lines
· Autopower Industries Street-Sport Roll Bar
· Sparco Flash 5 Steering Wheel
· HKB Steering Wheel Hub with cruise control buttons
· Sparco Torino Seats and Brackets
· Sparco Pedals
· Sparco 3” SFI Certified Harnesses with Cam Lock Buckles
· Sparco Fire Warrior Fire Extinguisher
· All Interior Panels reupholstered utilizing Sparco Black Jaquard Material with matching black carpet on lower door panels
· Custom Black 1A Auto form fitted carpet in front drivers compartment
· Custom matching rear carpet completing rear seat delete and extending through rear hatch area
· Custom made Leather Shift Boot and E-Brake Boot
· Autometer EGT, Boost, and Fuel Pressure gauges
· Knock Link and K&N AFR gauges
· Custom Hood Vents
· Kaminari Rear Spoiler
· Hella H-4 Headlight conversion with PIA bulbs
· Kosei Racing S5R Wheels, 17x9 rear and 17x8 front
· BFG G Force TA KDW Tires, 275x40x17 rear and 235x45x17 front
