Is this a real Turbo A engine?
lagged
1991 1JZ
new rochelle
Doward said:
I don't see an AFM. But I really doubt that's the original Turbo A turbocharger, so hell - as far as I'm concerned, it's not a vintage Turbo A, that would be worth some $$. This is just a modded 7MGTE
oh lets just completely forget about the turbo A head, the MAF set up and various other things. :icon_conf
try reading up a little more. mkiiitech.com
Doward
4,245
Alachua, FL
There is no MAF setup, and yeah, it's got a bigger TB, bigger 3000 pipe that's not stamped, etc etc.
None of that, imho, really matters. MAFT-Pro + Ron's FFIM + Q45 TB = hell of a lot better.
The head, now, that could be interesting... all I've found over on mkiiitech.com is a pic of the combustion chamber - nothing a good port/polish wouldn't take care of.
1200det
Australia
Certainly looks to be a Turbo A engine , Or at least Turbo-A Aux parts
Toyota Map on Firewall
Inlet Air Temp sensor in back of Intake Manifold
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
It's a Turbo A motor. Or at least, a 7M-GTE running on Turbo A electronics/accessories. The part number on the ECU is for a Turbo A, whether it says 92 or not has nothing to do with it.
The Turbo A motor had a larger turbo, no AFM, and a larger 3000 pipe, that is almost the entire extent of the changes.
TurboWarrior
Canada
The 3000 pipe on a Turbo-A is the same size on both ends and does not say "3000" it is blank. I had one my jdm motor came with it which made me wonder if mine was turbo-a at one time. But I don't think it is because the turbo was the same
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
then you did not have a turboA pipe. I had a blank one also that was non turbo-a
http://www.turbo-a.net/modules.php?name=Content&pa=showpage&pid=43
there was a turbo-a pipe on ebay a week ago, it was not bottlenecked.
