Is there a PrecTurbo rep on SupraMania?
williamb82
907
4
Tampa, Fl.
dbsupra90 said:
william-
850+ ship eh? how does 750 w/ the gt40 cover and 68 t4 turbine sound?
ck-
thanks man!
sounds good to me. looks like ill be posting this badboy for sale very soon. lol. ebay here i come. lol
Chris-Supra
Minneapolis/Lakeville, Minnesota
Looking to do a gt40 of sorts when I get my tax return, not sure what I want really. I really wanted a gt35r but I dont think the funds will allow the extra $600. What I'm looking for is the gt40xx configuration that would yield me 500rwhp on pump gas (93oct- ~18psi) and spool ASAP. I'm not looking for some magically spooling turbo or anything but from what I've herd the gt4082's with a .81a/r exhaust was spooling BEFORE 4000.
So what would a gt4088 .68 a/r exhaust do relatively? The .81 does about 4300rpms full spool (according to jt2ma71's dyno graph on SF) would 4000-4100 be a good guess? And the same for the gt4082 .68 and .81? Approximate spool times: 3700 and maybe 3800? I would like a good balance of top end and spool. I'm not a spool nazi or anything :)
dbsupra PM sent about pricing- thanks
Chris
339
Alpharetta, GA
Opting for a .68 A/R turbine housing for a GT4088 or larger compressor wheel GT type turbo I consider a bad idea. Note, the GT4088 is 56 trim, which indicates the compressor wheel is 88mm (exducer) and 64.7mm (inducer). Also, the flow efficiency, volume (mass), and power delivery of this turbo is far superior when compared to other "T" type turbo's of relatively equivalent size. Therefore, there is a substantial risk of part throttle surging induced by the small A/R turbine housing. My previous SP63 was a surge monster when it was coupled with a .68 A/R.
The advantage of the "new" GT type turbo's, standard journal bearing or ball bearing, is its excellent flow pattern, so don't consider limiting and choking the turbo's flow pattern and performance by undersizing the housings.
HTH
williamb82 said:
i want the gt cover if possible, thats why i asked about the gt4088 with a 0.68 turbine(the 0.68 turbine is sold by precision, thats who i got the part number from). im thinking of just selling mine and buying a larger one. though the gt4067 seems a lil pricey for a non bband also has a larger turbine then i want, and yes, i need a t4 flange turbine. so how much is the real gt4088? cheapest ive seen so far is like $850 + shipping but it comes wit hthe 0.94 or 1.05 turbine so the 0.68 would be bough separate. which i may have the turbine already, i told my folks i wanted it for xmas, so i guess i need prices with the 0.68 and wit hthe std turbine housing as well.
dbsupra90
toonar
indiucky
hi howard-
i dont think there is a problem running the gt40 w/ a 68. it is bascially the same size as a sp67 and by no means does a 68 choke that down. sean dyno'd his car w/ the 68 then the 81 and saw very little difference. meaning the exh housing even at 30psi and 644rw it was not a restriction. granted he does have a 4" dp, but the housing was not a choke point.
as far as surging, he only runs idle and wot haha. but the gt40 does have an anti surge housing fwiw.
williamb82
907
4
Tampa, Fl.
HTH
well, i dont plan on using race gas so will never run the boost high enough imho to warrent a 0.81 turbine and would prefer the 0.68 for spool. i figure i should be able to get 550-600rwhp with this turbo and turbine combination on 93 octane pump gas and water injection and thats the goal, no juice or race gas.
williamb82
907
4
Tampa, Fl.
dbsupra90 said:
hi howard-
nah, this car will be driven on the street, though no long trips do to the 1:1 final trans ratio of ha autoatic. also, i plan ona 3.5in dp if ossible. might be a tight fit welding a 3.5in vand to that turbo and then getting a 3.5in bend behind the turbo wit hthe ebay manifold. also, im using a 50mm wastegate to prevent boost creep. i figure with such a small a/r on the turbo the larger wastegate would help keep it regulated properly.
Chris-Supra
Your setup is identical to what mine will be william. I am leaning towards the .68 gt4088 as well, I want an easy 500+rwhp on pump as well. I want to try and get a 4" downpipe in there though, I will probably end up bashing the firewall in a bit to make it fit haha.
X-man
member
Dec 5, 2005
309
Pulaski,Va
HTH
I never had any surge issues with the .68 housing on my SP67. I only lost about 150 rpm in spool up going to the .81 and it is still a blast to drive.
Sean
dbsupra90
toonar
indiucky
dave talked to precision this am about a/r sizing on the gt40. this is what they said-
I talked with PTE about this and here is the skinny. They do offer a .68 a/r T4 turbine on the GT4082 which has a smaller turbine wheel. They sometimes put the smaller turbine wheel on the GT4067 and have a .68a/r on that as well. But the GT4088 has the larger turbine wheel, and they do not have a .68a/r for that, only the .81a/r. He said they could make a custom GT4088 with the smaller turbine wheel and .68 housing, that will cost extra, he didn't tell me how much.
williamb82
907
4
Tampa, Fl.
according to garretts stie they are both 77mm diameter turbine wheels. anyhow, id rather have the smaller wheel wit the 0.68 housing. lmk how much extra it would be. thnx.
dbsupra90
toonar
indiucky
Chris-Supra said:
hmm, the .81 gt4088 is a little more spool that I would like. Think the gt4082 with a .81 would get 500+rwhp on pump gas?
well, it will depend on other mods and what your idea of safe boost is for pump gas. it should be in the ball park tho.
dbsupra90
toonar
indiucky
ok so gt4088, gt cover. smaller turbine wheel w/ .68 housing. will do. cant imagine it would be much more since it is just some machine work involved. either way its still gonna be a lot cheaper than $850 + another housing ;) i'll let you know what i find out.
thanks
dave
williamb82
907
4
Tampa, Fl.
thnx. if all goes well ill have the cash for it maybe as early as next week.
edit: also dont forget the polished compressor housing. ;)
Chris-Supra
Mods = see sig. Sounds like about what I want though for a turbo, I'll be pm'ing you before the end of december with the money to pick up a gt4082 .81 a/r (assuming I dont change my mind again haha)
Thanks for the help-
