Is the GT3540R turbo worth the money?
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
tte said:
I could bolt this onto the stock manifold with an adaptor right?
Cheers,
Roy
yes it could but locating a CT to t3 adaptor is rather difficult. if you find some one who can do i let me know im in the same boat
drjonez
the motor city
www.4cefed.com
Blackfin said:
It's most readily available in T3. With T4 you are much more limited on housing options so you need to shop around to find the best for you. A call to HPF may be helpful cause they can source several Garrett resellers.
PTE carries a wide range of T4 housings...
csnow
Matthew 6:33
Palm Bay, FL
I would have to agree, I dont think the 35R would flow 500 on pump. Run meth or race gas and it wont have a problem hitting 500.
tissimo
Stock is boring :(
Melbourne, FL
61 p trims have run close to 500whp on pump.. not sure on the differences in the exhaust wheel between the P trim and gt35 exhaust.. but you can probably get close.. (high 4s)
Blackfin
Beach Bum
Jun 16, 2005
205
John's Pass, Florida
I was thinking that and even made a quick check of PTE's website but their price list only indicated a single T4 housing.
I almost bought a 3582R from PTE 6 months ago but ended up ordering a PTE 4088R through HPF since I was able to get a better deal packaging.
Also, If I recall correctly you can get a divided T4 housing for the GT35R but I can't remember from who.
dbsupra90
toonar
indiucky
yes, the gt35r is available in both t3 and t4 turbine housings. either you could use with an adapter on the stock manifold.
i agree the gt35r will do 500rw, but thats really pushing the boost high for pump gas. if you want 500rw on pump gas you might look into a pt67. however, that will have more lag than a gt35r. the 67 is offered in a ball bearing to offset that some.
i sell the 35r for $1149 or the pt67dbb for $1125. let me know if i can help.
tte
Breaking In - in progress
Northern California
Why does the gt35R more if the pt67 can do 500rwhp easier than the gt35r?
Also do you sell the gt35r with internal wastegates?
Cheers,
Roy
Silvermk2
MkII Weenie
Apr 4, 2005
99
Stockton, CA
tte said:
Where did u buy your one from?
Cheers,
Roy
Mines an ATP housing bought off Himini Racing on ebay. I'm not exactly sure why people are saying that it won't make 500rwhp. There are already a couple of 17-19psi dynos in the 480rwhp range on 7Ms out there. This turbo does 500-600 awhp on Evo fairly commonly. The turbo feels its best in the mid 20s area. I haven't dynoed mine but I can easily run to almost 100% injector duty cycle on 550s on mine so I have to be in the 500hp area.
I've posted this before a few times but just to add here the T3/T4 GT3540R/3582/GT35R's are all the same thing with the same wheels and nozzles it's ONLY the Flange that's different so NO a T4 GT35r won't make more HP than a T3 one.....
And yes it all comes down to tune if it'll do 500 on pump and how close to the edge you're willing to get.
