Is my ecu going out the door???
1jjosef
65
charlotte
92 full 1jz swap running open dp walbro 255 fuel pump NGK4644 spark plugs knn 4in air filter it hits full boost at about 12-13psi and it hits it strong with no brake up and it idles ok but some time it wood go crazy and start misfiring making a lot of white smoke and the motor cant idle and dies out..am thinking its the ECU because i called Aaron at driftmotion and he told me that its a common problem with the 1j ecu and that it needs to be re caped
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
Could be the ECU, check your spark plug gap, coils for cracks, wiring for cracks or breaks as well as reversed wires from someone trying to fix it before.
1jjosef
65
charlotte
what should my spark plug gap be at? coils are in good shape
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
I think stock 1jz should be ok with .32 gap i had ngk irridium plugs with this gap and they performed really well with stock boost.
Another MkIII
697
Chicago
White smoke is coolant. Could be a turbo, headgasket, or a leaking water pump, among other things. Have you tried pressure testing the cooling system?
EDIT: If its causing it to misfire/die, it sounds like a BHG. That is assuming its burning coolant. But you say it only does it sometimes, so IDK. I would start by pressure testing the cooling system.
-AM3
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
turbo will be blue smoke but doesn't usually produce the same symptoms. i usually tie the "weird" stuff to the ECU as they are known for their.. "reliability"
1jjosef
65
charlotte
that's what am thinking am going to buy another ecu and try it out THANKS!!!!! FOR THE SUPPORT GUYS
