92 full 1jz swap running open dp walbro 255 fuel pump NGK4644 spark plugs knn 4in air filter it hits full boost at about 12-13psi and it hits it strong with no brake up and it idles ok but some time it wood go crazy and start misfiring making a lot of white smoke and the motor cant idle and dies out..am thinking its the ECU because i called Aaron at driftmotion and he told me that its a common problem with the 1j ecu and that it needs to be re caped
