Ok, car is an original 92 Turbo swapped to a 1JZ. The lights on the instrument work, Speedo works, but the Fuel, oil, water and RPM don't work. Any suggestions?
pocketrocket07 said:Ive got everything but water temp, but i just supplemented with aftermarket in a pod. Good luck with it.
Freshmaker said:
Freshmaker said:The MA71 M1 Male connector on the right thee is what you have on the body. The JZA70 connector is what may have come on your engine, most of the time that connector is cut off though.
The M1 is a yellow plug located near the ECU. See it has most of the gauge connections there. I noticed it has the dash ground in that connector, so it may be causing your problems. I would check that ground first.
How did you modify your harness?
Evilempire1.3JZ-GTE said:Did you extend the harness or leave it factory?
Simply not extending the harness avoids this often.
The small jumper harness is easy to fix and re-pin
the 1JZ haves two oil sensors idiot light is the pressure switch next to the ac compressor screwed into the block
the orange led in the tech is for oil level warning system lets you know when your engine starts to run low on oil.
also helps to use the jza70 tach because it is diffrent from ma70
AF1JZ said:Did it work already, or did it just start doing this out of no where?
porsches4lunch said:It hasn't worked since i got the car. I applied a direct 12V+ to the water temp and it works. I applied Ground to the oil pressure and it worked. So the gauges, and connecting on the original plug side apparently works. The issue seems to be from the 1JZ plug (IG1) to the sensors, plugs, etc...
