my friend and i just did the install on a SX AFPR, innovate wideband, test pipe, and 12v mod. When we get all the work done and stared it up the wideband shows its running very lean (16.2-16.5). We set the AFPR at 40psi with vac line off, so we then set it higher to try and richen it up. No luck, so we then adjusted the afm screw, we screwed it all the way in. no luck there either, so then my friend unplugged the o2 sensor and it went to (12.8-13.1). So any thoughts on this would be great. why does it run fine without the O2 sensor, and is it Ok to run the car with out it? I put a brief mod list to let you know whats been done. and pics of the AFPR. thank you very much guys.
fresh jdm 7mgte
ct26-57 trim
blitz nur spec exhaust
titan divorsed down pipe
test pipe
apexi intake
walbro 255
rc550
lex afm
turbo xs blow off valve
greddy timing belt
titan mhg
arp bolts
perrin mbc (15psi)
we will move the wideband later, just temporary.
fresh jdm 7mgte
ct26-57 trim
test pipe
apexi intake
walbro 255
rc550
lex afm
greddy timing belt
titan mhg
arp bolts
perrin mbc (15psi)
