tbcmorris;1224997 said:do you have anything to back this up? i was taught that idle is not one of the parameters that needs to be met in order to operate in closed loop. i was taught that it was more dependent on engine temp than anything. leading me to believe that there would be 2 different idle programs. one to satisfy cold startup idle(closed) and warm idle (open)my car idles at about 14.7 open or closed loop. my problems comes in on my WOT AFR where i dip below 10![]()
well cold startup is indeed open loop. everything after that is closed loop until some percentage close to the 70% mentioned above.
jetjock on here told me a while back when i was having problems with my a/f also.
@mk3tattoos
You really don't need an aftermarket standalone ecu. maybe a fuel computer to keep your fuel economy down a bit.
My car is running a perfect 14.7 idle with 550/lexafm, an aftermarket afpr and safc. All mods to support the bigger turbo.
