installed mbc, still only 5psi
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
I'm thinking that there is something wrong with your MBC. Close the valve all the way and see if you can blow through it with an air compressor.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
ok i reomoved the pressure line from the compressor and couldnt blow through it at all.i winded it out all the and i blew through it while winding it back down until i couldnt blow anymore...it seems as if i stoped where i had set it yesterday so i propably just didnt set it far down enough?i will play with it later cuz i have to go to school but it just seemd odd that i had wind it half way down and still no results (didnt wanna blow anything up)
so it seems like i'm a pussy for not messing with it some more but we'll see later today :icon_razz
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
ok false alarm, i turned it aprox. 4 turns after i stoped blowing air through and now i'm getting 8.5-9 psi!damn it feels good:icon_bigg i still wanna fine tune it to 10 but i'm happy with it now...thanx and im sorry for the confusion guys, i just didnt wanna blow anything up.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Sorry to hijack this case closed thread but It makes more sense than starting a new one. I,v done just about everything I can think off to seek out a similar problem. Boost leak check, turbo has minimal shaft play and no smoke. I shimmed the waste gate about 1/8th of an inch today and on top of that opened my home made bleeder valve all the way and I still only hit 4 psi in 2nd and 5 psi in 3rd. What could this be???:1zhelp:
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Close it fully . Then Back it out 5 turns . Then Drive the car.Just dont drive with the controller CLOSED. Less vaccum More Boost. Vaccum OPENS The waste gate. REMEMBER CLOSED WILL BLOW IT :aigo:
Supraboy89
357
Hampton GA
your home made bleeder may not be bleeding enough pressure out. also 1/8 of a nich is not enough shimming to make a difference you need about 1/4 to about 1/2 inch
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
I doubt its a problem due to not bleading enough I dont think I could blead any more if I just pulled the hoses off! Could my factory exhaust be choking my turbo too much for it to spool any higher?
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
negative, but Im building one as we speak. So theres a good chance its my exhaust? First cat probably. I didnt think exhaust could choke it bad enough to limit me to 4-5 psi
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
How much of a restriction do the stock mufflers and stock elbow cause? I do have an RT cat laying around here somewhere that I will throw in when I my downpipe is done. Hopefully I can pick up a 3 in elbow soon to go on as well, but the way it looks now, I will be running with the stock elbow and 2nd cat back exhaust for a while.
