I'm thinking that there is something wrong with your MBC. Close the valve all the way and see if you can blow through it with an air compressor.
GC89 said:Sorry to hijack this case closed thread but It makes more sense than starting a new one. I,v done just about everything I can think off to seek out a similar problem. Boost leak check, turbo has minimal shaft play and no smoke. I shimmed the waste gate about 1/8th of an inch today and on top of that opened my home made bleeder valve all the way and I still only hit 4 psi in 2nd and 5 psi in 3rd. What could this be???:1zhelp:
p5150 said:yes - very good chance it is the first cat in the stock downpipe that is clogging it up.
