I'm changing my timing belt and this is what I found. What does it indicate?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
thedave925;994534 said:
Frank, by what method did you retorque the crank bolt?
he held the flywheel with his bare hand and used his feet to turn the torque wrench
Dec 3, 2003
6,653
Canada
GrimJack;994256 said:
Truth. New bolts don't cost much from the local dealership, though.
Yup, a must.
On the other hand, for those having problems, put your back into it - I've BROKEN these bolts, by hand, more than once. (Getting the rest of the bolt out of the crank after you snap off the head is a BITCH, btw.) I'd use the torch method and replace the bolt / damper before I go through that again.
Ask me how I know that one ;) make custom sleeves to fit over the snout of crank to ensure you get the drill perfectly straight and take about 2 hours to drill it out. VERY VERY, time consuming and hard work. Been there, done that.
Duane
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I'm thinking that too. As soon as it was mentioned, I remembered that there is this ever so slight little rattle type noise. It's not consistant though. I may go a week without hearing it.
Hey Aaron...thanks for the hook-up on the Intercooler by the way. I do appreciate it! :icon_bigg
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Honestly, i would just get another torque wrench and try again. I highly doubt the torque wrench you boke was in good shape and more than likely failed from wear/manufacture imperfection or some fracture from a previous use. A typical 1/2" drive handles upwards of 500ftlbs of torque and that's probably disregaurding safety factors in the specs (of course this heavily depends on what its made of and how its made).
gte
14
Hamilton
Rennat;980919 said:
i used an air gun and it came off. used the same way to put back on.
(i tried to tighten in 5th with the e-brake. just slipped my clutch... LOL)
You either were over tightening that crank pulley or your clutch is garbage. 196ft*lb's shouldn't slip on your clutch.
supraguy31
626
Pembroke, NC
Ok, Getting back to his Original Question. When I had my first 7M built a few Years back I incountered the same thing. Timing belt was riding to the back part of the timing gears to the point that the Belt was being eaten into.
I decided that... OH SHIT... Let me get another belt on there, Short story, Pulled everything apart and once I got the front timing belt cover off, I looked and the Back part of the timing belt drive gear on the crank had come apart and there wasnt anything keeping the belt from sliding back into the motor. Switched it out, Installed a new on and havent had that Problem since. I can Pretty much guarantee you that this is the Problem. the outer rings on those timing belt drive gears come off pretty easy.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
i just tore my spare motor apart that was sitting in my garage. the crank pully bolt cam of no problem with a snap-on impact gun. that is what i would recommend. crank up the psi on the compressor too. i think mine was at 150psi. the hammering of the impact gun is what gets it.
