I'm addicted to meth.
No not that kind of meth........I just got through installing my Snow's performance meth injection kit a while ago.
I dont' have any methanol to run in it yet. I did try it out with pure water, but I didn't have the tip installed into the intercooling pipe. I can't believe how much water was coming out of the tip. I'm using the tip that Snow's performance recommended for six hundred horsepower. Before I run my car @ 20psi. I'm going to do some more research. I have the blue kit that comes in their package. It is suppose to be equivalent to the m15 that other companies use.
I installed a green light that comes on whenever the pump is on. It's installed in the plastic piece above the glove box and it's really bright. I compressed air through the vacuum line to check it to make sure everything worked. It comes on @ 7psi, and then comes on full @ 19psi. I installed the nozzle about 18" from the throttle body. It's about half way from the cold side of the intercooler and the throttle body.
If anyone has any experience with the meth kits, feel free to give me some pointers. Thanks, Jay
Drugs are bad...........mmmmmkay?
7thousandpiecesMGTE;1228577 said:
Nice, I want to do this on my car in the future so I will be following this thread to see how it goes for you... or maybe methane instead:sarcasm:
any pics of the install?
No pictures as of yet since I haven't replaced my stolen camera. I'll get them soon though.
buckshotglass;1228583 said:
How do you know if you didn't even try it yet? You could water lock the motor and swear off the stuff forever.
This title is not accurate.:)
Please don't post in here about waterlocking the motor. I barely sleep as it is.......:aigo:
Go count your cars and trucks or something...........:biglaugh:
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
I figured he'd be too busy working on his supra to go count the rest of his cars.:sarcasm:
buckshotglass;1228617 said:
I don't want to see my friend Jay overdose, that's all.:p
I counted. 12.
Thanks for the concern Dave, but no need for an intervention quite yet........:biglaugh:
Fuzz420;1228622 said:
Nice jay, ive been wondering about meth kits. Get this thing tuned i want to see some new pump gas numbers
I will probably tune it friday if my meth/water gets here. I had to buy it from Summit already mixed. I'll find a better distributor somewhere and mix my own probably. I like to keep all the buds for myself............wut?
Nice.............:evil2:
tissimo;1228636 said:
Nice, I cant wait to get meth on my celica.. 25 psi on pump gas should make for a fun little ride.
I'm a little bit of a chicken shit Justin. I'm only going to run 20psi and about 18degrees of timing. How much timing do you think I could run safely with the meth? I know it says you can increase your timing but I've never seen anyone post how much they increased theres too.
I tuned mine at 17psi and I made 467rwhp and 443rwtq. That was with 15.5 degrees of timing from about ten pounds of boost and on. I'm sure that's safe if not conservative. I think that two and a half more pounds of boost would get me at about 500rwhp and then two and half degrees of timing should give me another thirty or fourty more horses. I think I should be around the 550rwhp mark with my 20psi and 18 degrees. How does that sound?
tissimo
Stock is boring :(
Melbourne, FL
Each engine will be different, so no one can say an exact amount of timing. Just get on the dyno and see where the engine is happy.
FWIW, my celica only has a 20g turbo and will make 375-400awhp on 25 psi.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Living in a place that snows alot of my friends have Evo's and STis. Meth definitely makes a difference and helps make alot of power. Keep an eye on the meth level though, disappears FAST when your out having fun.
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
Add nitrous. If you aren't hooked then I dunno what to say. The combination of 125-140 octane with a cooling dense charge of -125"f plus adequate fuel and added timing plus extra airflow and built in low pressure and level safeguards of both kits = a street tune and a race tune of +150-300hp.
Thanks guys.
IJ, what tip are you running if you can remember.............;)
Duane, It's hard to take pictures without a camera. I'm going to be on the lookout for one today though. If you're lucky, I'll even post up some pictures of me............:naughty:
Fletch, I'll keep an eye on it. My car may blow up but it won't be because I ran out of the juice.
Mr. Paw.........no nitrous for me, but thanks for asking......:icon_bigg
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
why do you have to buy it from summit. ive seen people run window washer fluid, or is this not a safe practice? im thinking of buying a kit for my build and i just want to know how readily available the meth is.
The window washer fluid says it has meth alcohol in it, but it doesn't say what percentage. I know the stuff I'm getting from Summit has 51%water and 49%meth. I would like it the other way around, but until I find pure meth so I can mix my own, I'm stuck with this. It cost me nine dollars a gallon and you have to buy four gallons of it. Someone tole me that prestone wwfluid was fifty fifty, but I haven't found any yet.
