I know some of you are running the Stinger EMS. I know some of you have had trouble fine tuning your cold start issues.. and find your cars idling at 400RPM; dying at any jab to the throttle..
I started searching around for a simple valve, similar to a VSV that comes on MKIII's from the factory, but a 'VSV' that will flow more air. I found that using the VSV would only give an increase of about 50-100 RPM's.
I was looking all over for a solenoid that would do the trick but not break the piggy bank. bingo...
http://cgi.ebay.com/ebaymotors/ws/e...37;3AMEWN:IT&viewitem=&item=130194528356&rd=1
(description: 1/4" Barb, Chrome ELECTRIC SOLENOID VALVE For Air Horn)
I ordered it, had it in a few days, and had it installed in less than an hour. Here's what I did.
1) Found a post-throttle body vac. source that was large enough to accommodate the 1/4" valve. I avoided using vac lines that connect to the ECU and fuel pressure regulator as not to cause fuel issues. I chose my BOV vac. line.
2) I tee-d the line and ran it to the brass barb on the solenoid
3) I fitted a cheap breather filter on the threaded end.. perfect fit
4) I wired an aux. output from the stinger to the solenoid, the other wire went to a +12v source (you may want to use a relay, I think it will be fine for just a simple solenoid).
5) Made sure I had a SOLID TUNE (at idle at least)
6) I set the Stinger's aux. output as follows: (your settings may vary).
RPM activated relay control
-On above RPM - 50
-Off above RPM - 700
-On below RPM - 700
-Off below RPM - 50
You could also use temperature activated relay control, but I figured this way if the car tries to stall on me, the valve will also help to prevent that..
Token camera phone pic:
Hope this helps some of you guys.
-On above RPM - 50
-On below RPM - 700
-Off below RPM - 50
