Idle Problems.
Status
Not open for further replies.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
antman said:
if your boosting and its leaking.....what do u think it going to do on idle???
R u serious rite now??
did u even see the video, the car is IDLEING ok, no boosting, not enough pressure goin through on idle to make it leak. you will not sputter on idleing with a friggen boost leak, not like that kinda sputtering. uhm u done yet?
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
empera said:
hehe..hey hey be civilized* ppl. i really doubt its a boost leak...
Sorry bout that man, it just gets to me when there is so much BS information out there and they try to argue it. any ways back on topic
lmk when u change ur coils, and tell me if there was a change. :) good luck
empera
Authorized Vendor
Philly.
thanks, i hope its the coils and nothing serious :(
also, the car runs fine for a few minutes on startup...when it starts warming up thats when the problem occurs...
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
yep also chek ur gaps on the plugs:D
againstdawall06
298
mo
gap them less then spec, like 29. that might help the sputter under load. once it warms up does it idle fine? or does it just do it during warm up?
empera
Authorized Vendor
Philly.
im running vpc...so no afm...the tps was replaced and it seems fine, wat are the voltages closed and at WOT?
empera
Authorized Vendor
Philly.
up
ok i tried setting the Timming as directed by tsrm...and still the same problem...
socc924
CT and Philly
I just thought about this when i saw your fs thread... but wouldnt running "750cc" injectors that actually flow at over 900cc's with a 550 chip for your vpc cause problems? Wouldnt you be able to tune it right with the same rated chip? Just a thought.
empera
Authorized Vendor
Philly.
empera said:
ok it doesnt look like its the timming, i tried to reset the timming...did TDC and set the cps. Im using the big injectors but like i said before...it was doing this with the 440's
and underboost it does miss....
:icon_surp
socc924
CT and Philly
Oh. What chip did you have in it when you had the stock injectors in? Plus I see you said you reset the timing, did you ever check with a timing light to be sure?
When excaclty did it start doing this? Was it after installing anything new or changing anything?
empera
Authorized Vendor
Philly.
I've ran the 440 chip with the 440 injectors and it did it...i havent checked it with the light yet...Im not sure when this started...maybe after the 2nd manifold.
socc924
CT and Philly
Its just that from the way you talked this weekend, it sounded like the problem was you were running too rich. The car even sounded like it idled fine when I heard it.
empera
Authorized Vendor
Philly.
im only running super rich under boost...reason why i need smaller injectors. I hit 8-10psi and car drowns...heh
socc924
CT and Philly
Then I am unclear about the problem, I will have to waite till I get home later to listen to the videos.... Was I missing something this weekend, cause your car seemed like it idled just fine. And it seems like your only problem is not being able to control your fuel.
Status
