Yeah....
Automagic ftl. I bought a Supra to DRIVE, not to suggest where it point itself :3d_frown:
Manual advantages (just to be on the opposite end of SS
1) Direct mechanical connection between engine/transmission = Less parasitic drivetrain loss = more power to the wheels.
2) I can lose 2nd gear, and continue about my merry way
3) Battery died due to radio blasting while working on your buddy's car? Push start it!
4) $300 clutch job vs $1500 transmission replacement.
5) No cooling lines adding extra heat to your coolant system, or being a PITA when working with the radiator.
6) NO LEAKY TRANSMISSION PAN.
7) Much more respect when you can run consistently, with a stick shift.
8) No need for a 'shift kit' - if I want performance shifting, it's up to me. If I'm cruising and want the shifts to be buttery smooth, it's no problem. There is no 'compromise' with a manual transmission - you do as you want.
9) R154 handles more power than the A340e, stock vs stock.
And most importantly:
10) Though you may be able to put your hand on your girl's leg as you drive, it won't help you. She's still going to sleep with me, because even chicks know that MANUALS ARE COOLER THAN AUTOMAGICS.
10 reasons a stick is better than an auto. And two-step FTMFW.
