Hi guys!
So I fixed my coolant leak problem. And as I went to tighten the alternator belt tension bolt. It broke inside the alternator. So now the broken bolt is in the alternator. I go to drill it out and then the alternator moved and hit against the chasis of the car and near the fuse box in the engine bay. And it spark and smoke everywhere. Now my car won't start. I've looked at the fuses and can't find out where to look.
Thank you for your help!!
