Well i was out crusing the other day and i did a nice pull in third gear, Boost went up and then started to creep a bit with some hgher rpm's around 5K i think. The boost started to rise from .7 or .8 bar up to 1bar, then the car hickuped since i hit boost cut and cut the fuel to the engine. The Ambient air temp out side was about 22C - 24C i believe. I was a bit shocked since i have never hit boost cut with my engine before.
I have not really changed anything on it and the creep did kind of make me concerned obviously.
Mods are not much. stock Y pipe, Trust DP, no CAT, HKS Sport CAT back, and HKS Muchroom filter on just the rubber portion of the intake piping.
I saw all this on my elec boost gauge.
This was done in Third Gear.
I did try to push the car again to produce the same results. I did see the boost creep up again, but did not hit boost cut?
is it just a fluke?
is it just a fluke?
