***hp increases***
americanjebus
Mr. Evergreen
wa.
johnathan1 said:
So 14psi is the general consensus for an OEM headgasket? How long did the factory hg's last in Supras before they all started blowing?
theres really no way to know. Are you talking about the factory installed hg or the oem hg in general. Factory hg depended on the card you were dealt. My cars oem gasket blew at 60k miles, i've seen some at 180k miles on 12psi that havent blown yet.
CBLEGUY
Organic90T "Growin Roots"
Nov 24, 2006
127
Cape Coral, Florida
I just finished my HG job. If you don't know what you are doing, you going to be one very frustrated person. Make sure you have the tool to press the oil seals for the cams. I custom fabricated one. Some people say assemble the head out of the car, some say in the car. IMHO assemble that SOB out of the car, it is just easier. also if you use the ARP studs which I recommend, you will probably have trouble gettin the head back on because the studs are too high for the head to fit because of the firewall lip. I can say that there is a very specific order to how you put the car back together, if you don't follow, you will be taking parts back off to get other parts on. Good Luck and plan to spend some time!!!
CBLEGUY
Nov 24, 2006
127
Cape Coral, Florida
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
tmhutch said:
Wow, so before running any serious boost I need to pull the engine from my car and dissassemble it, take it to the machine shop and have deck and head surfaces machined??? That sucks!
meh... people push their 7m's to over 400 whp on stock HG, but w/ arp head studs of course... no machining needed there
(BTW, i did lapp my block, and have the head machined anyways :D)
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Do the head gasket.
It's a good learning experience and you get to know your car and it's engine.
I'm in the middle of mine right now and I'm learning a hell of a lot.
Don't be afraid to use the OEM gasket, I'm going to use one. (Just make sure you get ARP's)
I've seen a couple people who did the job right and are pushing right around 400hp on em.
I think it all just boils down to is if you take the time to do it RIGHT.
I'm afraid that mine is going to go wrong somehow, I'm trying to get it done quick while still trying to do it right. I think I'm good so far :)
You two washington boys that have been posting, PM me if you've got questions or need a hand, there's always people here in the NW willing to lend a hand to a fellow supra owner.
EdgeSupra
506
New Jersey
Don't do performance modificatios first.
You absolutely will regret it later.
I had to teach myself major patience when doing things with my car.
Only piece performance-wise on my car was a JawsGear DS, because my carrier bearing on the stock 2 piece was bad.
Take the time to look the car over THOROUGHLY and replace anything that needs it.
I can't tell you how many times I went to Toyota with a list of 8-10 things at a time that I bought for replacemnet.
You won't regret it later. It's better to start off mechanically sound then trying to go fast while the car falls apart around you.
-Justin
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
-Justin
Listen to this man....lol.
EdgeSupra
506
New Jersey
Lol, Ben.
What a lot of people need to realize is the Supra is like a high-maintenance woman.
Gotta give her what she needs first, so she'll put out later.
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
Yeah def nothing like a Honda...Be very careful with your mods and def fix things that are broken or are reallly old. And research the mods on this site before you buy them!!!
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
Obviously, everyone seems to think that you should do maintainence first.....but if you're only trying to get around 275-350 hp you can safely and easily get power gains without doing much. I only have a 3" full exhaust, K&N FIPK, lexus AFM, and intercooler pipes and I've noticed signifigant changes. Without a boost controller I already boost at 9 psi safely for 60,000 miles (now 160000). If you think that more power is needed, then you most certainly will have to go with a MGH, some general upkeep, and some fuel upgrades.
tmhutch
8
Seattle, WA
Thanks, much appreciated. I've noticed a strong NW contingent for the Supras. More so than other brands I've been involved with.
Todd
Cya
628
Columbia, S.C>
Like everyone said, get the engine up to snuff. Better yet, build the block and put the MHG while doing your maintenance.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
Todd
yea I'm here to help.Just let me know if you need any. Kylefoto will vouch for me. BTW i just got my engine back in TODAY.(i bought my car in June.) I've never heard it run. I should get a chance tomorrow if all goes well. Why so long? Because I decided to do what was right and build the bottom end with je pistons, eagle rods, all balanced with the HKS 2.0 stopper MHG now I'm $3000 into a car i have never even heard run but you know what I know that the car is going to run great and never fail on me as long as i do everything right. def. at least put a MHG in and inspect you car its worth the time.
