Honestly, it only uses as much throttle as necessary. On a stock car it wouldn't boost at those times, but of course who's stock anymore? :rofl:
Nope. It wouldn't work that way. Instead, it would not applhy ANY throttle at all, until it got tot he point where it hit the controller threshhold, then it would pin it (Up to almost zero manifold pressure) until it got back up to speed.Canuckrz;1769465 said:So if the cruise is vacuum operated, could you theoretically if install a MBC or similar in the line thereby limiting the throttle the cruise uses to not go past whatever you choose to set it at?
Canuckrz;1769552 said:I'd have to argue that point, back when my car was bone stock it would break into boost with cruise control all the time on the highway with any kind of slope. Like I said previously its throttle adjustments seemed pretty abrupt.
Therefore limiting the ammount of pressure the engine can produce under cruise (even if you're still below the stock gauge's vacuum still) could theoretically give much better gas milage. That being said a steady right foot would likely still yeild the best results.
Also theoretically good synthetic oil in your transmission and diff could yeild a minor milage increase, or atleast this what seems to be reported on some of the hypermiler websites. I had done too much else the car in conjunction with my car to say if any of the results I had were related to the synthetic gear oil or not.
At least on my NA auto, I seemed to get better mileage with the trans set on sport. However, this was 90% in town driving, talking a lot of low speed 30-40mph stuff.Nick M;1769576 said:I prefer rolling into boost with cruise when climbing a hill over a down shift. Leaving in normal and not sport really limits the downshifts on hills.
Poodles;1769592 said:Good oils definately improve milage. So do thinner oils. The RX-8 runs 5w-20 in the US to achieve standards set by the EPA. Of course the rest of the world they run thicker oil and the engines last longer as it was designed for 5w-30.
Poodles;1769592 said:Mine was abrupt until I adjusted the assembly and removed the slack. A steady foot couldn't do any better, unless of course you slow down going up hills.
te72;1769620 said:At least on my NA auto, I seemed to get better mileage with the trans set on sport. However, this was 90% in town driving, talking a lot of low speed 30-40mph stuff.
Crypton2006;1770824 said:My friends and I often joke that Crack would be a cheaper addiction.
STREET90;1772232 said:Is getting 17-18mpg normal 260 miles per tank
mx83 cressida same weight as a supra
7mgte stock only 6000 miles on it with intake, 2.5 intercooling, big intercooler, 3" exhaust but 2in downpipew58 trans, 3.91 final gear, and 215/60/15 tires
Crypton2006;1770824 said:I really dont see how you guys do a hundred mile trip without getting into boost
..lol I get between 16-18mpg at 490whp R154 and a 4.30...
Nick M;1772490 said:Why do I need to go into boost?
I am not suprised. Your engine speed at 70 mph is probably close to 3000 rpm. It isn't about having fun, I get that milage on road trips. Not in the daily commute.
Crypton2006;1773388 said:I think you misunderstood, I ment that i have a hard time going a long distance with out intentionally getting into boost. Believe me i have a 67mm and i have to REALLY want to boost or the big grumpy snail inst going to wake up..lol
