theWeezL said:Hey man dont let the turbo guys get you down. Your NA is a fun car and actually has a couple areas it shines in. I preferred my NA when attacking a tight uphill course. Having to wait on power coming out of a corner just wasnt as good. Will it be faster than the turbo? Dollar for dollar the answer is definately NO, but there are things you can do to make it faster than it is at this moment. You wont see any big gains in performance unless you spend big $$$, but some mods are reasonable.
First off makes sure that the car is operating at full poential. Good plugs and wires, correct timing and a clean fuel system should be the first thing you do. Airflow is the critical factor in making more horsepower, so use a good air filter. Putting it behind a heat shield is a good idea as well. Put a header on it and a decent exhaust. Dont make the mistake of going too big as the NA likes backpressure. Reduce weight, anything you can do to make it lighter will make it faster, but be warned, you may not like the car after its been gutted.
The last thing you can do to make the car is to make yourself a better driver. Learn to use what you got. If you have a drag strip nearby, take your car to it when they have a test and tune day. Try to find ways to make you have a low reaction time, good clean launches and smooth gear changes (if you are 5spd). Try to beat your time every time you line up.
Last piece of advice is to take care of the car. Im guessing you are pretty young and most young people abuse their first car (maybe even a few more).
Supras dont like abuse or neglect. Watch your temperature and oil pressure. Check your oil EVERY time you fill up. I dont know how many times I've read about people "rod-knocking" thier motors simply because they didnt bother to check the oil level.
Anyway, enough of my preaching. Enjoy your car for what its capable of but dont expect miracles. Have some fun with it.
phoenix6 said:BC, he has sworn off the Nitrous due to fellow friends and racers stating its cheap or cheating.. I say, if its real, its available, hows it cheating? Did you strap a gameshark onto your 7m? Of course not.. did you sell your soul to satan? Nope... you took another route of power...
